I know my draft was pretty bad with the original 90 and shorter chimney. The smell seemed better with the higher draft. It would suck to lose draft because I already have some smoke spillage with 0.08" draft. Do get that Ashful if you are running at 0.18" draft?
So other than the turbulence theory I've heard another theory about creosote soaking into the door gasket.
I'm running a larger E-W load with some gap to the glass at about 55% tstat setting. It worked completely fine like this over the weekend without a flame. That last creo smell I had was with logs within 1-2" of the glass. Don't know why I would be the only one with that issue though. Some of this years stash was cut at 17.5" which gets it a little close to the glass.
