Ashful
If your bypass was that hard to close, it was likely obstructed with some chimney chunks on the gasket. Mine were both like that after I hired the dealer to do my first year cleaning, they apparently didn’t know you had to sweep all of the crud that falls out of the chimney into the cat chamber, they just cammed that lever over hard to compress all of that crap into the gasket. Between that and two other issues I had with them not doing what they said they would, they aren’t coming back.
The best way to get at that area is to pull the stove pipe. Second best is to contort yourself and reach up in there from below. Just make sure that bypass gasket is clean all around, no bits of crud on it.
. Apparently my wife was up a few times last night and did not smell anything upstairs. I was also up once. Had probably 1-2hrs left of active coals this morning. Started a quick full reload and out the door in about 20 minutes. I set it close to 50% for the day, let's see how it runs. At some point I can see it stalling and still making some smell, but that should be gone with practice...
