The draft test read around 1.2 -1.3 if I remember correctly.
Inthewoods, I agree with your local tech that the problem you experienced was due to excessive chimney draft. PE says the optimal draft for the 2020 LE model is the same as the 2019 Super Series models, 0.04 water column. During EPA testing, the test flue developed updrafts as low as 0.011 (sustained burn) and as high as 0.089 (draft control wide open at startup). An updraft of 1.2 to 1.3 wc is simply off the charts.
The main modification PE made to the Super firebox to meet 2020 standards was to replace the linkage which controlled the air supply to the secondary fire with their patented EBT2 device, previously used with great results in the Summit/T6 and Neo fireboxes. The EBT2 is designed to open up when chimney updraft increases during stage 2 of the burn, as described on our website at
https://chimneysweeponline.com/hoebt.htm.
So, your Super LE model has three sources for incoming combustion air: the primary draft control, the boost air pipe and the EBT2. You have some control of the primary air control, but the other two are balanced to supply the proper amount of air to the fire when chimney updraft is in the 0.04 wc range, with a maximum of 0.09 wc.
At 1.2 - 1.3 wc, your chimney is vacuuming an excessive amount of air through the uncontrolled boost air and EBT ports, even when your primary air control is turned to low. I might have tried a 5" rain cap, to reduce the updraft, but your tech's solution of blocking the boost air intake seems a reasonable solution (with your extreme updraft, you're not likely to ever need boost air).
