The timers are just basically the ole spring wound bathroom fan timer/switch...at least that's what I used
If a window cracked open is considered an acceptable trap than no. I agree with the heat loss but than again I would still be heating the air entering that room which by the way is a 1008 sq/ft open floor so would that really be a loss? Maybe I would be wasting my time messing with something so minor By the way that same air feeds not only the Tundra but a gas water heater, cloths dryer and bathroom vent.Did you make a cold air trap for your fresh air pipe? That usually works out pretty well in my experience. Cold air only pulled in as the furnace uses it.
I think preheating the fresh air through the "plenum" will result in cooling the heated air to the house...resulting in a net loss.
Too much heat loss if you put the coil in the firebox, (screws with secondary combustion)(plus ultra high temps on the coil) and temps are too low to make it work worth a darn externally.Just haven't seen to many EPA stoves with this mod wondering if there's a reason
That info is here in this thread somewheres...here's some help to find it...https://www.hearth.com/talk/threads/tundra-heatmax-information-guide.157330/i want a temp controller but confused about it. i saw the link for them which ones are you guys using and how are they all set up wiring temps etc.
Yeah the Kuuma was designed for this option...the Tundra not so much. I suppose you could figure out a way to pull some heat off the unit, but IMO that would be a lot of trial and error cutting and welding to get the best spot worked out...and then you are still stealing heat that could be put into the house (which is the primary reason for the furnace) I know for me, the Tundra isn't any too big for my house, so I don't want to put additional "load" on it. If Tundra is plenty big for your house, and you don't mind some trial and error testing, then I'm sure someone could come up with something that works at least to some degree.Kuuma's have an optional water coil which can be bolted to the rear of the firebox on the outside. I have one and use an old 40gallon electric water heater as a tempering tank for my LP water heater. Our LP water heater doesn't run nearly as often in winter as it does in summer and the supply feeding the LP water heater is always nice & warm. There are only two people in our household too, so that also helps.
If I do anything to save money on DHW, I may look at replacing my water heater with a HPWH once mine goes out...the verdict is still out if it would be worth the extra money or not (for me)
Of course its worth it. Do it before all the rebates (state, fed, utility) are gone. I saved $1,200 to $1,500 a year with one. About $700 now that oil is so cheap.
No rebates in backwards Ohio.I've not found any rebates around heres on 'em
Even if there were a rebate through the power company, we wouldn't get it. Our community owns its own (basically non profit) electric power plant and they don't seem to participate in that stuff...we do have reasonable electric costs though...at least for now.No rebates in backwards Ohio.
We save around $40 a month over a standard electric hot water heater with our HPHW.
I have my temp controller installed - finished it last night. I installed it and the timer exactly like @3fordasho, including the configuration settings.
It seems like my stove after the initial burn, will bounce between the 255 Low Alarm Limit and the 355 AHYS Alarm Hysteresis somewhat frequently. When it hits the 355 and closes the inlet damper,it seems like only a minute goes by before it hits the alarm again and opens the front damper. I obviously set the AHYS correctly to 100. This is only 3.5 hours into a load of 4 4-5" ash splits- wood is really coaled now.
