it took me a good hour to read this thread today, i even got yelled at by the boss for spending to much hearthnet time...
Gunner said:elkimmeg said:Gunner I working diligently in getting the first representation of a manufacturer to address issues on out board this is a giant step forward. There are alternative solutions for each owner with overburn stoves agreeable to them and VC. But the popost has become bigger that these two IT VC stepping up to the plate here.
MSG I agree sounds like overdraft. Aslo it would not be the first $10 stove top thermo that read incorrrectly I got 4 here you can have cheap. That's why I monitor the stoves with 2 each
Gunner where was PE to slove the guy in NY that could not produce heat in his PE summit. IF you remember correctly I had a hand in getting that resolved Not PE
This may be a good thing Hearth,net got reconized today by the largest manufacture of hearth products in America Hopefully we can attract some of the other major players
What is your point? I can't ask questions because someone named vermont is stepping up to the plate?
What does one incorrectly installed summit have to do with this thread? Nobody from PE wrote him a letter saying it wasn't supposed to produce heat!
Chill Elkmiester
MountainStoveGuy said:Gooserider said:While on the topic of manual problems, I've spotted another issue that could cause a problem. This is one where VC isn't the only offender - I've got a downloaded Hearthstone Heritage manual with the same issue It is also possible that I'm misunderstanding the code, if so I think there's a possible clarity issue with the code.
We all see frequent reference to the "2-3-10" rule about chimney height. My understanding is that the height measurment is to the top of the flue exit where the smoke comes out, and does NOT include the cap. To me this just seems intuitive as one could otherwise have a chimney with a low exit and a tall cap...
However of the FIVE VC manuals I have, THREE show a chimney with what looks like a cap on it, with the dimension line drawn to the top of the cap. Two have a truncated cone like object that is included in the dimension. The Hearthstone manual is worse however - in other pictures that use the same style of chimney the top peice is specifically labeled "chimney cap" - and the dimension lines go to the top of the cap screen and don't include the "roof" of the cap.
It would seem to me like they could come up with a clearer drawing, or possibly include one additional sentence in the blurb on the rule such as "These dimensions are to the top of the chimney only, and do not include any chimney cap."
Gooserider
I dont look at manuals when i sell chimneys, mabey i should. when i address the 10/2/3 rule i use the pipe only, before the cap is installed. that rule is used to prevent downdrafting eddies of of other roof structures, so if the top of the cap is in that envelope, i would say thats bad. As elk likes to say, better safe then sorry.
Gooserider said:MountainStoveGuy said:Gooserider said:While on the topic of manual problems, I've spotted another issue that could cause a problem. This is one where VC isn't the only offender - I've got a downloaded Hearthstone Heritage manual with the same issue It is also possible that I'm misunderstanding the code, if so I think there's a possible clarity issue with the code.
Gooserider
The way you do it is the way that sounds right to me, and I can understand not looking at manuals (beyond maybe an occasional skim) if you already know what the rules are. My concern would be for the person that doesn't have your background and just goes with what the manual shows in good faith... IMHO this is even more questionable than my earlier issue about the questionable website customer install photos, as this is something that is clearly put out by the company in an "official document".
I don't have a great deal of sympathy for someone that does something the manual says not to, but I do when the manual gives ambiguous or wrong info, or leaves things out. IMHO if you are going to provide info you should either do a complete job of it, or say "this product intended for professional installation only" and leave out the "How to DIY" info. Don't tell people how to DIY, but leave out stuff that only a pro might be reasonably expected to know.
Gooserider
I kind of feel the same way about a gov’t inspection - it does not make me feel any safer about the job. However if there were a good PRIVATE certification agency, I’d be more inclined to trust their approval.
Note: if you attempt to reduce your chimney updraft with either type of damper, you do so at your own risk. Only a few of the woodstove manufacturers we know of recommend the use of stovepipe dampers, and then only in cases of extreme overdrafting: many specifically forbid their use
what was you previous stove and how did it perform?
cmcramer said:Dollar bill test shows all gaskets to be tight. Can't say that I can locate the primary air flap to check for debris that may be hanging it up in an open position - where the heck is it?
OK. You Pro guys have convinced me, I think. I'm off to buy a damper and a gizmo to measure the draft. ('air velocity meter'?)
Manual Damper OR Barometric??
Also note that the (broken link removed) article about overdraft that was recommended to me included this:
Does VC "forbid" their use? The VC call center guy reading off his computer screen definitely said, with emphasis, "We get asked that a lot, and NO! No damper."
Will installing a damper void my warranty, Mr. Vermont?
