I had a scrap piece of 3/4” I tried to make a DIY turbulator. I think so. My 1800i has small deflector in front of the outlet I added a piece there to reduce the space under the stick deflector to 1/2”. My goal was to increase the flow path.
Any steel that’s not galvanized will work. Thread is here.
So I’m considering a DIY turbulator.
What is it?
See Jotuls diagram #73. It’s a structure that increases turbulence above the baffle to increase heat transfer to the stove top.
Why?
I’m trying to dial in a self diagnosed over drafting insert. It has a damper but I’m still not convinced it’s operating at peak efficiency. That stoves will be detailed in an another thread.
If Jotul thinks it’s worth it, is it worth try to make one myself? What would you use? I have about 2.5” of space above the baffle.
My thoughts are 2” tall pieces of 3/4” or 1” angle iron maybe 5-8 of them...
- EbS-P
- Forum: The Hearth Room - Wood Stoves and Fireplaces
@ABMax24 took the defector concept about as far I one could take it. A steel large coffee or vegetable can could be cut with snips and shaped similar to what ABmax24 did as an experiment.
You are going down the modification path. You need accrue data and be willing to keep experimenting. Don’t expect success first try.
Is it very interesting thread. Cool ideas. Basically just trying to block the flow in different ways. Key damper would be trying to do the same thing for me right? So which road do you guys think I should go down first? Key damper, or customized deflector addition?
