I can read your frustration as I would be too, dropping that money and not staying warm. But comprehend too yourself when people here tell you that 625 flat out is cool for a king king overtop of the cat. Something isn't right and people are just trying to help you out. We've seen no pictures of the actual setup so everyone is guessing online from your descriptions.
Measure draft, measure wood moisture, try cracking the window. Answers to these questions will help if you are serious about wanting to sort the issue.
And the type of install you described of a hood over a freestanding stove leading into the return air of your forced air electrical furnace is not allowed, in the WETT manual it just references the national building code and has quite a stern warning about these type of setups. I paraphrased it quite a bit, I'm still poking around the bc building code for further reference.
That's not bad. You're a good sport Trevj. So I took a couple pieces of fir out that I had sitting inside split them, brought them back in and tested. I saw 16-18% with my meter.
Mano or not, the flue is undersized. A Proper flue is the number 1 requirement from BK. 7" single wall pipe into a 7x8 clay flue. 7x8 square will not do as well as an 8" round flue. I really think the undersized flue is the issue here..Oh, this ain't about sport.
I AM really frustrated with this stove, the process around buying it, the restrictions of choices in technology levels, getting the install signed off, and esp that it really has not met my expectations.
The smoke flare when loading, and the Cat housing below the door line, are cumulative to that. Additional irritants.
Yeah, this wood could be a bit drier, but as I am seeing it, falls into the range that would be considered decent wood. Not ideal, but decent.
Now I gotta track down a manometer.
Based upon some of what I have been told here, I may have reason to have a chat with my retailer. I went to them and explained what I wanted, got this. I have no intention of not knowing bloody well enough to be able to carry on an informed conversation if it comes to it. It's been...educational!
I'll see if I can find my camera and post a pic. I would not have thought it hard to visualize straight up, a 90 degree bend formed from two 45 degree bends and a straight run horizontal to a thimble on the side of the cinder blocks, which, I observe, are supporting the brick of the open fireplace up in the living room, aside from providing some warm thermal mass throughout the vertical run through the house.
And I really should sweep up the spiderwebs that are there beforehand!
I appreciate the help.
Cheers
Trev
For giggles, I just walked out and pulled a block of the same off the pile, and split it, measured it immediately and came up with 21.4 to 21.6 percent on the inside face of the pieces.
A basement window preferably in the room the stove is in if it has one. The idea is if your warm air is leaking up and out of your house if there's not enough makeup air coming into the basement it can weaken draft. So allowing makeup combustion air(through the window) may help your stove draft and burn hotter.
I have to run here shortly. Feed horses and head to town so I'll check in later about the furnace/add on when I can sit and collect some thoughts.
Yes but a square liner has allot of turbulence in the corners and that reduces both volume and velocity pretty dramatically. he sizing charts for square and rectangle liners are very different volume wise than round liners. Even oval liners hurt draft. But again there are allot of stoves including kings running on square clay lined chimneys. And if the chimney really is 30' I doubt that is the issue. You may very well be right it could be over drafting.Why not? 7x8 is 56 in^2. 8" round is 50.62 in^2. It would seem that the masonry is perfectly sized per the fire code if not a little too big. And then it's 30 feet tall!
You could always break out the old clay and put in a stainless liner.Well since running a new chimney through the middle of the house isn't really in the cards, and I was assured that the drop in size would NOT be an issue, what else do I have, besides a bargain for somebody else?
In a perfect world I suspect it should be able to be ducted from outside directly to the stove combustion air inlet (why DON"T they do that?)
Trev
Trev it is easy to detect your frustration and perhaps even a little disdain for your Blaze King at this time, you seem to be throwing in the towel way to early however. There are many many happy Blaze King owners on this site, it is definitely not a bad stove. From what I have read I believe cat stoves seem to prefer wood at between 12% - 16% moisture content, your wood is not all that bad at +-20% or so. Out of curiosity have you tried adding a small eco-log in your load for testing purposes, these are extremely dry and have high a BTU content, I say this because I would be curious to know what happens with the temps in one or two trial loads with just one eco-log mixed in with the rest.
I still think you have a flue & chimney problem, have you discussed your problem and situation with the selling dealer and what exactly is his take on it.
It sure would be useful to know what the exact draw is on your chimney.
So you are having problems but did not ask the dealer for advice???? That should be your first callNope, not talked to my dealer yet. at this point, I am disappointed in my purchase, but my thoughts on the dealer, or maybe more correctly, the sales guy, are impolite.
The king is a convection heater, I don't think it's gonna produce enough heat for the hood to work worth a damn. Even if the top gets to 800 the duct works is probably not insulated and will lose almost any heat it picks up by the time it gets to another room. A king at 600 should be throwing plenty of heat.
Get the fans for the stove, if that fails to work get a wood furnace and be done with it.
We see it all the time where people go from face searing pre EPA radiant heaters to modern convection heaters and are unhappy.
How often did you have to reload the old stove? How long is the king burning?
Then why did you pay a premium for a stove that excels at that?Like I said several times, if I wanted a 40 hour burn and low heat output, I can light a candle for that.
