even the 1.5 CF keystone is supposed to make 40,000 so I suspect some cooking of the books...hard to trust that EPA chart but it's the only thing we have.
I'm seeing 35 K for the Keystone. For sure, some of the numbers seem screwy. Maybe the wackiest I saw, the Englander Madison SSW01, 12000-26300 BTU/hr. Then the SSW02, 19472 – 22961 BTU/hr??
![Confused :confused: :confused:](/talk/styles/default/xenforo/smileys/confused.gif)
Just a bad test run, or what? You wouldn't think that would be the case, with fixed fuel loads, and the mfgr. running their stoves at four different air settings. That said, I've run the Woodstock Fireview, Keystone, and the Dutchwest 2460 here. I never ran any of them flat out, but running in my normal ranges, the EPA numbers for those stoves correspond to the outputs I saw here. I was running the Buck 91 in a different house but that rated 51200 BTU/hr, weather right or wrong, was melting the buttons off my shirt!
if you used the shop I think you did, I would not be to surprised you got bad info....I did some shopping there. I wasn't interested in a BK, but they pushed it SOOOO hard regardless of my interest of the Summit. It annoyed me so much I refused to buy from there
That's not the first dealer I've heard of pushing the BKs like they were the be-all and end-all, but I guess that's to be expected...
that does not give him a reason to insult and demean those of us who know more then him about stoves and chimneys and are trying to help him
I was only commenting on why he hasn't been around.
Even if he's gone, at least we got a chance to kill some time. I mean, what else have we got to do? We are warm, there is nothing at all wrong with our perfect stoves, and a load of wood lasts for several days.
Other simple solution......Sell the BK for 3 times what you can get a Timberidge 50 at CT and stop fighting the battle. I burn dead standing fir all the time (judgement is needed as some is ready some not) and get a clean hot burn and easy over night burns. If the pipe and thimble are the issue, this would be easier and you would be putting money back in your pocket.......
I think he'd be fine with a large Drolet if the current issue is not solved.
This is what I would be looking to do. Hopefully he can get his money back, otherwise sell the BK for a bit of a loss, you still end up with money in your pocket. Stick the Drolet HT-2000 in there, as begreen suggested...numbers say it is a flame-thrower, and I'm seeing about $1000 US. Should handle the low-20% wood better as well.
The flue is twice the required size for a 6" connector. I think the rule of thumb says anything under three times the area of the flue can work, but the Drolet manual says to use a liner. With 30' of interior chimney, and a stove that tosses more heat up the flue, it may work without a liner...did with his old stove, apparently. But I'm no chimney expert, so it would be best to get advice from a certified pro. I also wonder if you could possibly run an insulated 5.5" liner, but it sounds mighty tight, with no wiggle room; Clay liner would have to be straight, with no mortar coming out of the joints or anything.
The un-insulated basement as well as insulation and air-sealing issues should be addressed for optimal heating, but I can see how the OP may not want to, as he is renting. Only he knows weather putting much effort into that stuff might pay off.
