Software limiting the torque below 10MPH on the Ford EV helps with that... for better or worse lolI think I would like punching it all the time. Tires would be a problem.![]()
You need to visit eastern PA. We have potholes that will swallow a Prius. On some roads, they occur every 150 feet, in spring.It's been so long since we've had a flat tire that I had forgotten about it. That was about 15 yrs ago and the only flat we've had in at least 40yrs. if not more.
Yes, I recall, now! You may have cleaner cities and better weather, out there. But like John Spartan visiting the underground, our meager shoulder-less roads -- where speed limits are a mere suggestion -- feel like home.Grew up north of you. Did deliveries into NYC sometimes and saw many a pothole. My SIL lost a shock due to one (and the county reimbursed her!) I've had my fair share of winter driving, potholes and road salt. Glad to leave that all behind.
Maybe this type of control system already exists and is commercially available. If so, I would appreciate info on where to read more about it.
Chevy says about 4 miles/hr on 120V. This could work well for a "typical" 50 miles/day of driving and plugging it in promptly after the drive. In effect the 120V charger simply would be topping off the battery every day. But for me a "typical" daily drive easily could be 85-155 miles, or 21-40 hours of charge time. Which is why I bought a L2 charger that provides up to 40A/240V, although the Bolt L2 charge rate is 32A. I got the 40A L2 charger thinking another future EV that would charge at the higher rate, or a L2 charger my son could use to his benefit when he gets his Tesla.How long would it take fully to recharge at a child’s house if you were limited to 120V?
After 6 weeks with the Bolt, including temps down to -10F and snow, I remain completely satisfied with the Bolt. Performance has been flawless. The goal of having an EV that could meet up to about 155 miles round trip on a single charge is being fully met, and in fact, I am venturing further than that and moving into the realm of Public DC fast charge stations. Earlier this week I used the Bolt to attend a two day meeting on a round trip of 320 miles, between my home and Minneapolis. I topped off twice using two different DCFC stations, just to learn how to use them. One was GreenLots, pricey, the other ChargePoint, very reasonable. On Wednesday I have a meeting at a location of 210 miles round trip. Depending on temperature and wind conditions, that may be a single charge trip, although the only recharge possibility is at the half way point on a L2 charger, and I likely will take an hour off and add about a 25 mile charge. I don't want to tend up "dead in the water" on the highway at some point before making it home.
Edit: 2388 miles on the Bolt so far.
As good as any car I have had. With the 17" wheels it has good clearance, better than our Avalon road cruiser. And I bought a set of winter tires for ice and snow, like we have on the Avalon. We have had winter tires for many years, and I would no longer drive with9out them.New How's she go in the snow Jim?
I'm glad someone is offsetting my consumption of fossil fuel. Cary on.I'm getting quite comfortable with the mileage/range gauge on the Bolt. Took a 204 mile round trip yesterday to a clean energy conference, temps in 30's to low 40's, head/cross-winds at about 15 mph. At the start, range gauge showed full charge and range of 202 miles, +/- about 30 miles as "max' and "min." Only available charge was a 110/120V (8-12A) outlet in the parking ramp at the 1/2 way point, my destination. I drove conservatively, using minimal heat and mostly keeping my speed in the 55-60 mph range. Headlights were on the entire trip. At destination arrival gauge showed 101 miles traveled and 102 miles range availability. When I left the conference and after a few hours of 110/120V charging (8A), the range gauge showed 116 miles range +/- 12 miles. Drove conservatively home, no headlights, and on arrival total distance was 204 miles with 21 miles range still available. I had no apprehension on the return trip because I knew the remaining miles to travel at two checkpoints, one at 70 miles and the other at 42 miles remaining, and at both points sufficient range was shown to be available. The energy report showed +1.5% for driving, -2% for climate control, and -5.5% for temperature.
The take-away is that the range gauge is quite accurate with known temperature and driving habits. A major weather change or unexpected driving conditions (traffic jams, for example) in route could deliver a surprise, but there would be plenty of warning by paying attention to the range gauge and knowing the actual miles remaining to be traveled. Also, while relying on 110/120V charging during a trip for any major addition to range is not reasonable, unless a long parking period is anticipated, a "bump" in charge over a short parking period can be very valuable.
I would like to know what to expect as range moves closer to 0 and how much, if any, extra miles actually might be available to handle an unexpected situation. But operating the Bolt to a fully discharged battery without a plan on what to do to extract a dead Bolt to a charge location is not very practical. Obviously, the best alternative is to be careful not to run the Bolt to 0.
I drive my 5.7L RAM when I want to conserve fuel, it gets close to 14 mpg. My sedan runs 10 - 12 mpg, depending on distance, terrain, and attitude. My prior coupe never got much better than 8 mpg, and only sat two, so I guess I'm headed in the right direction.I'm glad someone is offsetting my consumption of fossil fuel. Cary on.
But I admire what jebatty is doing, here. Resources are limited, we can't bury our heads in the sand. Conservation by those who are less interested in fast cars allows those willing to pay to play a temporary free pass to do otherwise. It's all headed in the right direction, there. By the same token, I'll avoid infringing on the limited resource of Spandex, to save it for his bicycle shorts.
Do what makes you happy, folks.
