Are you guys sensitive to smells in general?
Some guys are sensitive and some ashfords seem to emit an offensive odor. Sometimes you get really unlucky and both of these things happen at the same time. This looks to be one of those times.
You're not nutty if you don't want to throw the baby out with the bath water.I don't know why I still want to burn wood. I must be crazy.
I recommend electric heat, maybe natural gas. Sell the stove, and the whatever wood you have left. I'm not being facetious. Just doesn't seem like it's in the cards for you. Maybe give it another go after the kids have moved out and perhaps you've moved to another house. I'd have given up myself about 400 posts ago.Yes. I am calling BK tomorrow. They are plenty tired of hearing from me.
@Mnpellet there are at least 10 other people on Hearth.com with the AF30.2 that have this exact creo vapor issue. Just msging with one guy who is in process of extraditing his 2018 AF30.2 as we speak.
What a huge disappointment. This stove has so much going for it. Not sure what my options and actions will be next. I might try to burn a few last fires with the windows open and see if this plastic smell goes away while the kids are out of the house. Even with the stove cool it still reeks of that smell if you get close.
There is still a gasket on that side door also. Any time you are burning low and slow like with cats there is going to be more risk of smell. I know with the princess I used this year even though I didn't burn low all that much there was more smell than with any of the non cats I have used. It wasn't bad at all but it was there.@edyit Certainly I would consider a non-cat. Something like a Englander 30NC would not work with our house layout though and the inconsistent heat output could make it unusable for us. On the one hand, we did manage okay with 6-8hr burn times due to our Ashford issues, but a 10-12hr burn time adds a huge amount of convenience (only two loads per day). Depending on what happens with the BK return, I've been really eyeing the Woodstock Progress Hybrid if there is someway to make that happen. From what I can tell it has a really nice wide range of heat output, plenty great burn times and the side loading would remove risk of door gasket leakage like the BK design.
All loading doors have door gaskets and all glass has seals. The side door on the ph could leak too.
There are a handful of stoves on the market that can reliably give you 12 hours of actual burn time reliably. Woodstock makes a few of them and in all the years I’ve been here I’ve never read if a smoke smell problem from the Woodstocks. I would prefer the IS model to the ph though.
@Highbeam Yes, just that there may be an advantage that the air wash is not blowing on the door gasket of a side loading door. That's what some people are hypothesizing about the Ashford. Like Spacebus mentions, one problem with the auto thermostat is that the air is on full blast for a lot of the first 30min and way overshoots the temp you want. Therefore it has to shut down the air hard. That's where is smoking for me. A manual stove you may warm up for 15 min after a reload and you can immediately turn it down before it gets up to steady state temp.
Never smelled anything with the Keystone or Fireview.in all the years I’ve been here I’ve never read if a smoke smell problem from the Woodstocks. I would prefer the IS model to the ph though.
Ditto, I like having manual control. One of us is usually around to open up the air on the coals and get more heat, if it's really cold out. In average outside temps, with cat stoves I've run, room temp doesn't vary more that a couple degrees over the entire burn. Manual control was part of the reason I went with the old version of the T5 without the EBT2. I'm not convinced I made the right choice, however. Of course, I could tweak the old style T5 to totally manually control the secondary, but I'm obviously not going to do that to my SIL's stove. If the stove were mine, maybe I could come up with a way to have the secondary operate in stock mode, yet override it if I wanted to.I don't trust any thermostatically controlled stove. I know folks love them and it is more convenient, but I like having complete control.
The T5 has a big front door. The door gasket seals flat against the front wall of the box, as you can see in the first load pic in my thread. The Buck 91 did the same, with a big front door. I think that might provide a better seal than a knife-edge...or I could be full of crap again. Never any smoke smell with either of those stoves, and I was running the T5 when it was 60* outside. However, the stove draws unbelievably, and I could still open the door with no smoke roll-out.there may be an advantage that the air wash is not blowing on the door gasket of a side loading door.
I got better at starting new loads with a minimum of hassle, using good kindling and a SuperCedar chunk or two. Weather you start a new load with kindling or you do it off coals, you still have to monitor the stove until it gets up to temp and you cut the air and/or close the bypass. But yeah, the small firebox you have is going to require more re-starts.It's annoying to have to light it all the time, but burns are short and my house doesn't overheat.
Ditto. The welded-seam steel box appeals to me, but soapstone sure looks nice...I would prefer the IS model to the ph though.
One of the keystone's we works on smells horrible.Never smelled anything with the Keystone or Fireview.
OTOH, if we were gone for long work days, I think a thermostat would be good for automatically opening the air on the coal bed at the end of the burn.
Oh yeah, I spaced that out...again. In that case the PH would be in play for me and I'd compare the constructions of the two hybrid systems, burn times etc. I'd prefer to look at the soapstone, of course.The Progress is a steel box with a soapstone skin.
When it's burning? I've sometimes gotten a faint whiff of smoke right over the stove this year but I'm pretty sure I just need to replace the flue exit cover plate gasket (rear-vent setup.) It's not coming from the door. Could you tell where it was coming from on the Keystone you see?One of the keystone's we works on smells horrible.
