Crummy
Burning Hunk
The manual states "Excessive temperatures can be caused by many small pieces of very low moisture content wood being used as a primary fuel source." The wood I'm currently burning is SMALL diameter Black Spruce that was cut and single split two years ago. It was down to 12% a while back but now that the humidity is a bit higher it's up to 16% or so. I cut and split this wood for camping wood long before I even thought about a wood stove and it probably should have been left in rounds for the stove. I'm guessing this small/dry wood is probably a huge factor in the higher temperatures I can encounter. It's larger than kindling but probably averaged 4-6" rounds that I single split, if stacked in the Sirocco 20 tightly I can get 12 pieces in. It's burns great and will hold a fire for 20 hours if I turn it way down so all is good I just don't run it higher than 4:00. Should be far enough back in the shed that I can reach some bigger splits by the time we are in the - digits and need to crank the stove up. As BKVP said it's all good I'm just probably being overcautious and worry too much.
