Same here. It's one reason why I like to burn doug fir.Must be the wood. I emptied my Sirocco 30.2 2X maybe 3X Nov. thru March. Burn pine and fir.
But you're burning hardwoods. A few years ago, I emptied my King 1107 once, mid season. All I burned was NIELS.I have to empty ash every Saturday… x2 stoves, when I have both going. Part of that is the smaller belly of the 30 box, but even more so may be the difference in the wood we are burning.
Thats one great thing about the bio blocks, no ashBut you're burning hardwoods. A few years ago, I emptied my King 1107 once, mid season. All I burned was NIELS.
Not just hardwood, but almost exclusively oak, for the first seven years with my Ashfords. This year I will finally get into some hickory, and then I have miles of ash on deck behind that, but until now it’s been nearly 100% oak. I hear it’s one of the worst woods for coaling and ash accumulation, but honestly don’t have much else in recent years with which ti compare it.But you're burning hardwoods. A few years ago, I emptied my King 1107 once, mid season. All I burned was NIELS.
Ive burnt quite a bit of Red Oak and its great long lasting wood it does produce a lot of ash and coals. I found if I just pour the air to a bed of hot coals and let them burn down before reloading works best.Not just hardwood, but almost exclusively oak, for the first seven years with my Ashfords. This year I will finally get into some hickory, and then I have miles of ash on deck behind that, but until now it’s been nearly 100% oak. I hear it’s one of the worst woods for coaling and ash accumulation, but honestly don’t have much else in recent years with which ti compare it.
When I burned all the hardwoods, I'd rake them forward, put some well seasoned pine on top and let it rip. Only way to deal with coals filling up my stove...Ive burnt quite a bit of Red Oak and its great long lasting wood it does produce a lot of ash and coals. I found if I just pour the air to a bed of hot coals and let them burn down before reloading works best.
Id like to try some dry pine, but no one sells it around here and I have none on my propertyWhen I burned all the hardwoods, I'd rake them forward, put some well seasoned pine on top and let it rip. Only way to deal with coals filling up my stove...
Any tree service would likely drop off more than you can handle,,, for free !!Id like to try some dry pine, but no one sells it around here and I have none on my property
When one of our red cedar trees fall (as in last week), I split and stack it for this purpose. But I've also found that just throwing a single split of oak or other harwood on top of this raked-forward bed does almost the same job, albeit taking a little longer.When I burned all the hardwoods, I'd rake them forward, put some well seasoned pine on top and let it rip. Only way to deal with coals filling up my stove...
Nope. You're good to go....I asked about a month ago and the general response was a overactive cat since it was new. Been burning 24/7 for 27 days straight now and it hasn't settled down. This reading is 30 minutes after a hot reload with the thermostat at 6:00 for 15 minutes and 4:30 for 15 minutes. At this point I turn it to 3:00 and it will be high in the active zone for around 12 hours. About 3:30 is as high as I can go without it leaving the active zone and any higher than that I don't know that the needle would ever stop. Still nothing to worry about?
You maybe you should try a new speedometer. I did have one go nuts here a few years back. Condar has themI asked about a month ago and the general response was a overactive cat since it was new. Been burning 24/7 for 27 days straight now and it hasn't settled down. This reading is 30 minutes after a hot reload with the thermostat at 6:00 for 15 minutes and 4:30 for 15 minutes. At this point I turn it to 3:00 and it will be high in the active zone for around 12 hours. About 3:30 is as high as I can go without it leaving the active zone and any higher than that I don't know that the needle would ever stop. Still nothing to worry about?
They are hardly precision measurement devices. I have at least three, and when inserted into the same hole, they each disagree slightly with the other. I do remember past users replacing a flue or cat probe with another of the same model (usually Condar FlueGard to Condar FlueGard), and seeing a difference of 50 - 100 degrees.You maybe you should try a new speedometer. I did have one go nuts here a few years back. Condar has them
To me, the BK looks like a private-labeled Condar FlueGard, I'd be very surprised if they're not made by the same people, whether that's Condar or third-party to both. There was actually a post a few years back where someone (@Highbeam?) had made a comparison between the two, swapping them in the same hole and noting similarity needle position at a few temperatures between both.
Do you monitor your flue temps? It would be interesting to see those while your cat temp is up there and compare with others here.I asked about a month ago and the general response was a overactive cat since it was new. Been burning 24/7 for 27 days straight now and it hasn't settled down. This reading is 30 minutes after a hot reload with the thermostat at 6:00 for 15 minutes and 4:30 for 15 minutes. At this point I turn it to 3:00 and it will be high in the active zone for around 12 hours. About 3:30 is as high as I can go without it leaving the active zone and any higher than that I don't know that the needle would ever stop. Still nothing to worry about?
No I haven't. Was told all that mattered was the active/inactive so no flue probe was installed.Do you monitor your flue temps? It would be interesting to see those while your cat temp is up there and compare with others here.
Many here find an internal flue probe is a great tool to fine tune your burns. If you had one and it was also reading high it might tell you there’s a problem or not?No I haven't. Was told all that mattered was the active/inactive so no flue probe was installed.
