Mt Bob
For what it is worth,you can take hobby knife,scratch open the three circuits,for testing with meter, before unsoldering.Then these can be jumped back together with solder,and wire if necessary.
Bugs would you mind posting up the part # for the triacs you're usings? For those of us out there whose boards currently work but for future reference in case of trouble...
I have seen some Harman boards blow the fuse,with no motors hooked up,but does not take out a triac.Probably the transformer shorts after getting hot.
um,only when it is acting up,but maybe hook ohm meter to the leads,heat with hair dryer?I have ued hair dryer(well,my heat gun),and contact cleaner(to cool things down) to pinpoint bad/suspect items on a circuit board,but usually are low voltage items.Works really well to check capacitors.Should work in theory for transformer.Anyway to test the transformer on the board?
You are a wealth of info,And I thank you,in case others do not.But,the transformer is the largest thing on the board.Also,the 5v output also has to go through a rectifier,to have 5v dc for the lowvoltage components.I also have soldered bits of wire on pc boards,for testing,as,you are right,small and not much room.What I gave him was a quick everymans test.That transformer is very tiny. If its primary was to absorb all the power dissipated when the fuse blows ( 120 x 6 = 720 Watt ) then a meltdown on the primary side would have been the case. On your pic the transformer appears totally undamaged.
When the stove is plugged to the mains, the transformer is instantly active and its secondary is delivering power to the microcontroller through the 5 V voltage regulator. In this stand by state the current flowing through the fuse should be very low. Easy to measure with an ac-amp-meter inserted instead of the fuse.
Measuring the overall current flowing to the stove:
I have tried it, and for a 62 years old like me its a bit awkward to attach the alligator clips on the fuse terminals, since the fuse is pointing downwards. It is necessary to lie down on the floor.
Unplug stove.
Flip out the fuse.
Bugs, on your advantage there's no igniter plug next to the fuse terminal, so there's more room for the alligator clip, making it easier for you, but take care that the alligator clips don't touch anything except the terminals.
Ready to current measurement:
With the alligator clips safely attached to the fuse terminals, now plug the stove to the mains. Press no buttons! What amp-reading do you get on the meter? The idling board should only be drawing few milliamps, so it may be necessary to change the meter range. Unplug stove before changing the plugs on the meter if needed.
Now press the start button, but don't press the auger button. What amp-reading do you get, when the start up burst has settled?
The stove will now be running for 30 minutes, until it shuts down due to no fire, so a lot of measurements can be done.
Don't press the auger button this time, since we now are testing if anything else could be drawing too many amps, other than the auger.
This should be fairly easy, except for attaching the probes.
If you don't have an amp-meter ( multimeter ) with well insulated probe wires, don't do this test, but I'm sure you have.
Good luck and take care. Keep posting.
Sweeeet! Everything is working just auger out of the loop. When is the fused auger test?
So im leaning towards a temperature activated short in the transformer low voltage somehow getting a line voltage spike.
Guess we’ll have to see how that auger test goes
