Stovensen: I could never figure out how to take these motors apart without destroying them. Or I would have tried to replace the bearings.
If the thermal protector or the bearings 'went south' in one of my blowers, I wouldn't hesitate replacing them. I have the tools in my workshop to do it ( including a CO2 welder ).
On my Fasco blower motors the bearing end plates are welded to the stator housing, as you can see on my pic. A dremel with a grinding disk can easily grind away the four weldings on the endplates. After replacing the defective parts inside, all is welded back together.
![Whitfield died? Whitfield died?](https://www.hearth.com/talk/data/attachments/219/219568-c0bb2691192feb590eecb0e43f5e8825.jpg)
Other motors use special clips instead:
![Whitfield died? Whitfield died?](https://www.hearth.com/talk/data/attachments/219/219569-06aabed8a432c4a9c2d40bfc7b675503.jpg)
And the four rivets holding the bearing and oil felt together can be drilled out with a 1 mm drill bit and afterwards replaced with 2.5 mm screws. I have a 2.5 mm tap to cut the thread.
Hardest part, as I see it, will be finding bearings of the right size and quality.
