Very kind offer! No worries 👍Too bad you were not in NJ a few months ago. I had an extra one i would have given u. I ended up taking it to utah so next time fire season hits i can try to have breathable air inside.
My house a 1600 ft ranch so very simple design. An OAK wouldn’t really be simple for my application where the hearth is located (middle of house), never mind unsightly. My house sits right at the top of a “hill” so I think that’s why the fireplace always drafted well. Most of my windows with the exception of a couple have been replaced recently. The only other air consuming appliances in the house are in the basement (water heater and boiler).I was a severe asthmatic growing up, and my wife had a milder case. My kids each show some signs of it, but not as severe. So, this comes from that perspective.
A properly installed and operated wood stove does not emit any noticeable smoke or particulate into the home, but exhausting it just outside the home can result in having that exhaust drawn back into the home as make-up air through leaky windows, etc. If sensitive to this, you may find that it's best to not burn when the wind is coming from one particular direction, etc. The footprint of our house is shaped like a "U", with one stove at either end of that U. There are occasional days when the exhaust from one stove is drawn into windows on the opposite side of the house.
Installation of an outside air kit (OAK) can mostly eliminate this, if the OAK feeds air directly into the stove. Essentially, by eliminating negative pressure draw on the house created by the stove, you're not drawing any of the smoke emitted from your chimney back into the house. Of course, other appliances may cause negative draw, but usually not. Natural stack effect within the house usually dictates that all air drawn into the house comes in at ground level and exits at roof level, which is to your advantage.
Wood stoves operated without an OAK draw a lot of fresh air into the house, which must be heated, thus lowering indoor humidity. My house will run down around 20% without a humidifier, so we keep humidifiers running all winter. It's pretty easy to keep the house at a more comfortable 50% with one humidifier for each 2000-3000 sq.ft. This also helps prevent cold and flu, the susceptibility to which is somewhat dependent on dry nasal mucus membranes, due to low indoor humidity.
As noted previously, wood stoves do create dust, every time you open the door to load or clean out. But this is a very localized problem, and very easily managed. Get an ash vac, vacuum around your stove every week. Get a dust pan and brush, and brush up around the stove after every single reload. Get an air purifier, and place it in the room with the stove. We use a wick type humidifier, which doubles as a dust filter for the stoves.
I understand the need for outside makeup air to be added for combustion, I was simply stating that windows might be the lesser likely sources of air leakage, and could be from opening/closing exterior doors, through walls, etcWhether the windows are new or old, without an OAK you are drawing air from the house to eject outside. That is replaced by air drawn in from outside, no matter what the path. However, with a simple layout at the top of a hill, it's very likely anything exiting the chimney is moving away from the house, not being drawn back in through adjacent windows.
In an ideal world, yes, there should be no smoke leakage but in reality stuff happens. You forget to open the air first before going to reload. Some coals wake up or you uncover a small piece of wood not fully combusted so a little smoke rolls out. A log rolls onto the glass and you go to fix it so you don't have an off gassing runaway. Just being tired or lazy or in a rush. Smoke from outside sucked in. Etc. I was just saying smoke will absolutely get into the house accidentally. With a wife ready to pounce on a mistake or kids with breathing issues it'll be good to be diligent about these things.A properly installed and operated wood stove does not emit any noticeable smoke or particulate into the home,
Indeed it was. I am humbled.Nice work! More than an hour! 😉
Btw did you ever measure? It just looks like less than 2.5 cords to me. Naked eyeball. Though there are likely rows I don't see. It looks great.
Btw what brand cant hook is that? I really need to get one of those.
Not splitting this week, that’s for sure. Going to go at it with the 8lb maul at some point and slowly chip away at it.Yeah a cant hook is definitely my next purchase.
That should keep the wife happy. What's the splitting plan? How's your back? That's a lot to do in a day.
I'm heading outside to move wood as we speak.
I'd suggest trying a lighter maul if u can. The 8lb gets heavy fast and not needed for that load you have. Also i never stack rounds, to much double work. split them on the ground where they lay, then stack them. Just the way i do it, you may need to make it look neat asap though?Not splitting this week, that’s for sure. Going to go at it with the 8lb maul at some point and slowly chip away at it.
The other load coming tomorrow. If I feel up to it, going to do the same tomorrow as I did today.
I’ll tell you about my back tomorrow 🤣
You hit the nail on the head with neat asap. While it’s a little extra work, it keeps it organizedI'd suggest trying a lighter maul if u can. The 8lb gets heavy fast and not needed for that load you have. Also i never stack rounds, to much double work. split them on the ground where they lay, then stack them. Just the way i do it, you may need to make it look neat asap though?
The length? Or diameter?What are those, like 16"?
I should clarify. I cut some around 15” for N/S loads and then 16-18” for E/W loadsWe're a curious bunch. Both!
Good plan.I should clarify. I cut some around 15” for N/S loads and then 16-18” for E/W loads
