Single vs double wall flue pipe
Gunfixr
89
Va, USA
OK, so I did search for threads on single wall vs double wall flue pipe for wood stoves. I found several, but none addressed the question I have.
So, the question is, is there a difference in the efficiency of a wood stove, in particular an epa stove, with single wall or double wall flue? Does the insulating layer increase the flue's draft efficiency? I know it will radiate less heat into the room, I know it costs more than single wall, my question is only about how it affects the stove's operation.
Both works fine but with some stoves double wall is better. those stoves tend to have low flue temp and is better to use double wall. Draft issues with some setups too, double can help. Another important detail is clearance. Double wall allows you to set up your stove closes to the walls etc, if your stove is shielded also.
I too have questions on this topic. Before next heating season I'd like to change out my single wall to double wall with two 45's and out an insulated liner in my oversized clay tile liner. I already have a very strong draft and the stove tends to burn hot and fast, and that's with a 90 bend on single wall that rarely goes over 200f surface temp. The stove also has five 90 degree turns built into the smoke path. Is it possible to install a damper on double wall?
I look forward to next season when I have a probe in the stack!
Yes you can get dampers for double wall
Reactions: ShawnLiNY
Yes there is key damper for double wall and are real cheap and easy to install. Also there is stove top adapter built in damper if you dont want to be opening holes on the stove pipe.
Thank you.
Here's a photo of my flue collar. Are you saying I can get a damper that can fit the flue collar?
[Hearth.com] Single vs double wall flue pipe
If so, that would be perfect.
Thank you.
I recommend you ask @bholler. the one i use is the same brand of my stove pipe. I have on one setup the adapter and a key damper on my other setup on the pipe. I do like better the one on the pipe.
You say flue pipe.
But do you actually mean stove or connector pipe?
Flue usually means chimney. And not in the room.
Thank you.
It usually works better if the damper is 12" or so from the stove. But with your stove it may not matter as much
Do you think a damper would be beneficial for my install? I wish this stove had an adjustable secondary intake to compensate for the tall chimney.
If you are already running that cool on the surface of your pipe probably not.
You say flue pipe.
Sorry, still new at this. I thought chimney was exterior, flue interior.
Yes, stove or connector pipe, the one in the room.
The chimney is double wall, duravent double wall, stainless, with screened(?) cap, also stainless. Ceiling box is duravent triple wall/insulated.
Stove is Englander nc-13. At the chimney ceiling box, the pipe is 18.5" or 19" from the wall. Tapers back to about 16" or 17" down at the stove. Instead of running an extra wide or angled wall shield up, I took 8" pipe, split it, and mounted it over the 6" pipe, on the back 180 degrees. I used the same ceramic spacers used for wall shields.
Wall behind will get warm, but not hot.
I added the little side shields because the walls on either side got hot enough I didn't much care for it. You could leave your hand on it, but it was pretty hot.
The pipe is angled because the roof above has a peak which goes back, and putting the box where it is avoided having to mess with that.
  • [Hearth.com] Single vs double wall flue pipe
Well, I could run it hotter, but I feel like it might damage the stove. At the hottest part it will run up over 700 in a hurry if I chase flue temps.
I own a duravent double wall damper equipped appliance adapter. It's the first little 6" chunk of pipe you stick into the stove, comes with a key damper installed or without, and then you drop additional sections of double wall pipe right into it. Some stoves need an appliance adapter and some don't.
If the surface temperature of a piece of single wall is 200 when the stove below is over 700 then I suspect that you have a broken thermometer. Or, since 200 celsius equals almost 400 Fahrenheit you might be reading celsius. 400 would be about right for a 700+ stove.
His stove is a 2 tiered moroso. They do a very good job of extracting heat from the fluegases. In my opinion to good of a job
Reactions: Highbeam
Since warmer flue gasses make a stronger draft you get a stronger draft by keeping the flue gasses warm with the double wall.
Stove efficiency is unaffected by single wall vs. double wall unless you have so much single wall that your draft is reduced below your stove's required threshold. At some point your draft can be so low that the fire doesn't burn well. At some point you can cool flue gasses so much that creosote formation can be excessive.
Total system efficiency can actually be improved with single wall. Poorly designed stoves send a lot of heat up the flue in an effort to burn clean or to be simple. If you can recapture some of that heat, but not too much, with single wall pipe then it contributes to total system efficiency. Most wood furnaces have a back and forth flue arrangement on top of the firebox that they call a heat exchanger where room air steals heat from the flue gasses.
I have 10 feet of single wall above my noncat and I wish I could steal some heat from it. My noncat stove dumps too much heat up the stack. It's safe and works well but I know that there is heat being wasted.
I had very little creosote in the pipes when I cleaned them a month ago. That added to the expected accumulation from the total winter is probably less than a gallon from a 25' system. Obviously not amazing, but should improve when I get double wall and an insulated liner. There's not much advice on this particular stove out there.
I’ve been holding back on asking this same question (1st season install). I have doublewall stovepipe, but was considering going to single wall next season. The double stovepipe is one of those adjustable types, I assume just a shield really, and no insulation. I ended up not needing the clearance reduction (or is it gain?). Am I wasting too much heat? My stove heats my house well enough, sometimes too much (when that happens, on comes the furnace circulator to bring cold basement air up or hot air down).
Quadrafire Millennium 3100 EPA
6 feet of Chimney
5 feet of Stivepipe
No temp probe
No stovepipe damper
That is one point, I put in single wall to get the heat.
I've got more than enough. I end up trying to run smaller fires, and less air, and it won't run well. Bigger fire, more air, it runs well, but I end up running lots of fans and opening windows.
My wood isn't the best, so i'm not sure how much is because of that.
6 feet of Chimney
5 feet of Stivepipe
No temp probe
No stovepipe damper
I would keep the double wall. It's good stuff, stainless steel inner wall so it should last as long as the chimney. Welded and the double wall acts as both a heat shield and insulation to keep flue gasses warm and creosote accumulation down.
Both work but I think it's a downgrade to go to single wall in a normal home application.
Reactions: BethelStrong
Plus, that's a pretty short chimney.
