wagne223
I just reread the first post. It certainly sounds like a low draft issue.
Is it possible that the results from the draft test are incorrect?
Does the chimney terminate at a point above the roof peak/highest point of the house?
If you think smoke is coming from the air intake, then an OAK would help, but the OAK may just become a chimney if there is something wrong with the actual chimney. And that would be a much larger problem.
Another thought, you mentioned the smell is upstairs after a reload. Is it possible that smoke/oder from the chimney is entering the house from the roof, attic, window, or air vent on the second floor?
