haha we might do it sooner depends on the weatherSo install on Friday? If you get all sooty doing it...kinda gives new meaning to "Black Friday", eh?!![]()
either way that chimney is bad assyeah, it works good. Being in heated space and insulated pretty much the whole run allowed me to supply an outside make up air duct to my BD to send cold outside air up the chimney instead of heated basement air in order to regulate the draft. Been using it this way for about 1.5 heating seasons now.
If your new liner works, I'm not sure spending even more money on a completely separate and new chimney would be worth it. Obviously your call though. It would be better, but at what point does the law of diminishing returns come into play in regards to $$$$$ spent.
I think that on a cold windy night it would suck up small animals that ventured too close to the VF intake!either way that chimney is bad ass
You know I never thought about the BD sucking the nice heated air from the basement. I know your a numbers man, how much does you flue drop in temp doing it the way you are?
The chimney guys are braking the clay out now. Going with a inch of insulation plus double wall stove pipe in the house. Ill post new pictures when it's finished!
All in all I would have 3900 into the chimney plus whatever the double wall stove pipe is going to cost which I know is not cheap.
The draft is about .05 now. The damper moves around now too. It still doesn't heat very well though 67 inside on med 32 outside. Maybe I should add the baffles back in the heat exchanger and readjust the draft.
The draft is about .05 now. The damper moves around now too. It still doesn't heat very well though 67 inside on med 32 outside. Maybe I should add the baffles back in the heat exchanger and readjust the draft? Seems like it wants to bouce back in forth from c and 1 Is that normal?
it was hooked up. I took it off because I didnt want the rubber hose to melt. I measured it just below the BD.I think I would be putting the baffles in then getting draft in spec if you can, yes. Manual says they are there for hx efficiency but can be taken out to try to alleviate poor draft side effects. I would also try to get draft to upper end of specs (0.06) if possible, to start with. Make sure you have the gauge hooked up right, doesn't look like its hooked up in that pic above?
I'll level it not today though. I just need a break from this stove.You need to make sure the BD is level, both horizontally and vertically. May have to put an extension on the tee with an adjustable elbow to accomplish this. Or cut a piece of stovepipe at an angle.
Once you get the draft where it should be, then you should probably pick up a few cheap HVAC temp probes and put them in your supply plenum and return air plenum.
okBuy some copper tubing and make a connection to the rubber hose ~ 1’ away.
It does need to be plumb and level...but if you have -0.05" WC, then good enough for today.I'll level it not today though. I just need a break from this stove.
Yes that is what you want to see, as you get further into the burn cycle it will go from 2-1, 2-1-C, 3-2 ect. If it is going from 1 to closed then the thermo couple is reading a high enough internal temp in the firebox that you should feel more heat in your house. Are all hot air ducts unobstructed, are your air filters allowing enough air flow thru them. May be worth trying to remove the lid to the filters or remove 1 filter to introduce more air into the system. Have you removed the hood on the front of the furnace with the blower running as you should feel a lot of air blowing out there.Seems like it wants to bouce back in forth from c and 1 Is that normal?
I've never seen it go to 3 after being on c?Yes that is what you want to see, as you get further into the burn cycle it will go from 2-1, 2-1-C, 3-2 ect. If it is going from 1 to closed then the thermo couple is reading a high enough internal temp in the firebox that you should feel more heat in your house. Are all hot air ducts unobstructed, are your air filters allowing enough air flow thru them. May be worth trying to remove the lid to the filters or remove 1 filter to introduce more air into the system. Have you removed the hood on the front of the furnace with the blower running as you should feel feel a lot of air blowing out there.
I could have been a little clearer on that as later in the cycle it may go from 3-2 then back to 3 till reload,as far as filter removal it may be worth trying once to see if changes anything and go from there.I've never seen it go to 3 after being on c?
@JRHAWK9 says that he gets higher plenum temps later on in the burn when it starts to go back to 3 long term for the "coals burn down" part of the process.
today I got 10 hours. The blower was off for about 2 during that. I loaded on lots of coals more then I wanted to but the back of the stove was emptySo how long are your loads lasting, from loading to loading?
