maple1
Ya I've never installed one, hopefully it goes that well. Was sounding like maybe a tight fit to me.
Curious, what would be a better solution... Full liner down the chimney or a separate new run of Class A next to it? In my house I have my insert on my main flue with a SS liner with Vermiculite... If I ever was going to add a VaporFire, I have the original Boiler chimney flu that runs paralell to the fireplace flu... But I suspect that is smaller in diameter.
Not saying I'll ever be able to do this, but its always good to know. Maybe in the next house I will do this![]()
Thanks. Plus with the exterior class A, you could run an exterior clean out right? That would be awesome as you wouldnt have to do it indoors. Keep the missus happy.An independent Class A pipe is always the better performer but some people like the looks of bricks. To those people, I suggest building a chase around the pipe and applying a brick veneer. Pipe is smooth walled, straight, easy to replace, easy to install, easy to clean.
I happily demolished a masonry chimney system to replace with pipe.
my clean out is outsideThanks. Plus with the exterior class A, you could run an exterior clean out right? That would be awesome as you wouldnt have to do it indoors. Keep the missus happy.
I did demolish the masonry chimney in the summer. I didnt know it would matter. If i did I would have put a class A pipe up.An independent Class A pipe is always the better performer but some people like the looks of bricks. To those people, I suggest building a chase around the pipe and applying a brick veneer. Pipe is smooth walled, straight, easy to replace, easy to install, easy to clean.
Now that you have a nice new masonry stack, let's see if you can make it work! Sealing up the cleanout door and metal pipe connection in the basement should have helped more. 0.02 is low.I did demolish the masonry chimney in the summer. I didnt know it would matter. If i did I would have put a class A pipe up.
The chimney is 16 feet in its current state and its not perfectly vertical in the basement but it is at a 45. I just bought the liner for it. 20 ft one so I can add 3 ft more to the chimney. Is it going to work? idk its a 600 dollar gambleNow that you have a nice new masonry stack, let's see if you can make it work! Sealing up the cleanout door and metal pipe connection in the basement should have helped more. 0.02 is low.
23- 8" blocks plus 1/2" of mud between each for another 12 inches should get you a 16 foot tall chimney plus another 2-3 feet of vertical rise in the basement. So 19' of chimney and this masonry chimney is pretty "right" sized compared to most.
Something is still wrong. I believe that you should be having stronger draft from this chimney.
I'm betting yes...it will work.I just bought the liner for it. 20 ft one so I can add 3 ft more to the chimney. Is it going to work? idk its a 600 dollar gamble
I hope!I'm betting yes...it will work.
more block with the liner going through itHow are you adding 3' on? Having the block laid up higher, or class A conversion plate/pipe on top of existing?
I have 2 masonry flues in my house currently, in addition to the Class A that the Kuuma is on. I would have happily demolished them long ago, were not the structure holding up part of the house and the roof. But I do have plans... Flues made of stone and earth are a stone age solution that should have been abandoned long ago.I happily demolished a masonry chimney system to replace with pipe.
Yes but what they don't state is that its hard to get that with a masonry outdoor chimney. For people like myself that never had a epa furance that may come as a shock. I'm not here for that anyway. I just want to get it working.Hopefully (along with some sound advice from this forum) you get your draft issues solved as you will love this furnace once properly installed. Maybe one of the good things to come out of this thread is for people to know how important a role the chimney plays when it comes to burning solid fuels in any stove. (Lamppa does state on their website the required draft is .03- .06" WC).
Did you try to run the kumma on the stone ones? Was the class a put up special for the kumma?I have 2 masonry flues in my house currently, in addition to the Class A that the Kuuma is on. I would have happily demolished them long ago, were not the structure holding up part of the house and the roof. But I do have plans... Flues made of stone and earth are a stone age solution that should have been abandoned long ago.
If I knew all this in the summer it would have been a class A pipe. Lammpa should be more upfront when it comes to this imo. It would have saved me so much trouble but if they told everyone their chimneys aren't going to work I bet their sales would go down so that prob why they don't say.
No doubt there are much better options out there but it should be noted that if you do have an established masonry chimney (as I do)that meets the required draft the Kuuma can be vented to it and operate flawlessly . Mine vents to an inside masonry with a 7x11 tile liner.Flues made of stone and earth are a stone age solution that should have been abandoned long ago.
I did read it before I bought the furnace go to page 7 and you will see it does say you can use a masonry with tile linerPage 4 of the owners manual, item number 5 under installation instructions has it spelled out in bold. The manual is available for download by anybody at any time on their website. One of the first things I did when looking for furnaces was download the manual and read through it. It may have saved you some time and $$ by reading this before having it installed.
hopefully mine will be good too once it has the linerNo doubt there are much better options out there but it should be noted that if you do have an established masonry chimney (as I do)that meets the required draft the Kuuma can be vented to it and operate flawlessly . Mine vents to an inside masonry with a 7x11 tile liner.
It should be much taller with the 3 more feet yes. The peak you see in the picture is a lot more then 10 feet from the chimney. The one I'm worried about is not in the picture and is much closerHard to tell from your pics, is your current chimney higher than your roof ridge and if not will your modifications put you above it?
