That's way more than any printed numbers that I ever remember seeing for the VF100...that's not what he said but if that is the case that means Im way under
Like I said they had me make changes that I dont think they want me talking about on here so this is where im going to stop. Mines burning hotter then everyone else's.That's way more than any printed numbers that I ever remember seeing for the VF100...
ok so maybe hes wrong but that just means Im worst off then I thought@JRHAWK9 and I have a pretty good idea what they had you do...with that tiny screwdriver![]()
But yeah, probably not common knowledge.
I don't think anybody is cranking more BTUs out of their VF100 than what JR is getting out of the SpaceHawk100 ©![]()
I know nuttin'....no idea what you are talkin' 'bout Willis.
either way im going to need another stove then. I got about 100k I have to make up for.I know nuttin'....no idea what you are talkin' 'bout Willis.
The 160K rating of your old furnace was more than likely over exaggerated. The documented rating of the VF100 is actually more on the pessimistic side while the 160K rating on the Yukon was probably way more the optimistic side.
I was the one with the Yukon...and it was rated for 112K net...and it was a monster! So yeah, 160 on that Clayton is probably a bit high...and the gross rating too. Got to remember, these old beasts used 8" chimneys...so capable of blowing a buttload of BTUs up the stack!The 160K rating of your old furnace was more than likely over exaggerated. The documented rating of the VF100 is actually more on the pessimistic side while the 160K rating on the Yukon was probably way more the optimistic side.
Alot of it was going up the stack! My house was very warm then! I need that extra 100k no doubtI was the one with the Yukon...and it was rated for 112K net...and it was a monster! So yeah, 160 on that Clayton is probably a bit high...and the gross rating too. Got to remember, these old beasts used 8" chimneys...so capable of blowing a buttload of BTUs up the stack!![]()
yes with a new chimney$5500...wow, I hope that is with a new chimney installed!
Really? What size firebox is that (guess I shoulda looked it up, huh?!it would double my available btu
)it would double my available btu
AgreedI'm sorry...I'm just having trouble taking you seriously with that new avatar pic!![]()
Same size firebox as the vf100 according to the spec sheetReally? What size firebox is that (guess I shoulda looked it up, huh?!)
Unless that is a monster of a stove, sounds like someone is stretching the numbers.
Keep in mind that the VF100 has a 4.1 CF firebox, and a pretty elaborate heat exchanger (compared to a stove) so I'd say it would take a HUGE free standing stove to equal the VF100 heat output...and the biggest stoves out there still use a 8" chimney too.
Of course when thinking about it a bit more...you are comparing convective heat and direct radiant heat...and that's hard to compare really...
Oh yes sorry I was looking at the bigger oneI had to look for myself...from the brochure it is 3.0 CF, 25% smaller...
Ah, yes, the F5200...wow, it is a monster! And does use a 8" chimney! No wonder the price!Oh yes sorry I was looking at the bigger one
Maybe I should go with the biggest one just in case?Ah, yes, the F5200...wow, it is a monster! And does use a 8" chimney! No wonder the price!
Which one was the quote for?Maybe I should go with the biggest one just in case?
Personally, I’d be spending the money on air sealing and insulation. Insulation is a one shot deal and as @brenndatomu said, your ROI is 24x7x365. Feeding another stove is not.https://www.regency-fire.com/en/Products/Wood/Wood-Stoves/F3500
5500 for that stove installed in my living room not sure if im going to do it or not at this point
that would mean I would have 11k worth of wood stoves in the house. Prob still be cold.![]()
