I don't think so the most I've been getting is .06 when it's on 1 with tin foil over the BD. The only time it really needs the BD is when it's starting a fire from nothing. I went all out on the chimney I don't know how I can get anymore?
It was also with my best wood. I was down there next to it cleaning up the mess from all work so I was wacthing the whole time.Holey moley, I don't think I have EVER gotten 2.5 hours on pilot!![]()
yeah I was thinking about taking it out and just puting a cap on the T .... I covered it after I noticed it droping so I don't really knowNo problem it is what it is. 0.06" is great, I was referring to the 0.04" you mentioned before. Is that with the BD covered? Seems like you may not even need a BD...?
I wish I had that luxury in the dead of winter, but the house loses heat too fast so I have to load on a fair amount of coals.yeah I was thinking about taking it out and just puting a cap on the T .... I covered it after I noticed it droping so I don't really know
No way I would take it out! You will need it this winter. When its real cold out mine can't even keep up...its wide open and draft is still too high (at times)...that's why I put a manual damper in after the baro...take the edge off the draft so that the baro can do its job properly. (keep up) Just to be clear, this only happens (for me) when its 0 or below and maybe when the wind is just right...just keep the baro covered with HD foil if you don't need it...easy to pop off when its needed then. Or if you don't like the foil look it would be easy to make a sheet metal "cap" that just hangs on the front of the baro...paint it black, you'd never notice it.yeah I was thinking about taking it out and just puting a cap on the T .... I covered it after I noticed it droping so I don't really know
Ok will do. I loaded on a big bed of coals too. Hopefully as I get it more sealed up I wont have to as much.That's because you load on 0.001 ounces of coals.![]()
When I load on a good amount of coals in the dead of winter I get some good pilot times.
As long as you monitor your draft and it doesn't get too high, I don't see why you couldn't. Make sure you keep on eye on it though in windy conditions and put it back in if you see it getting too high.
Yeah but I wasn't even getting that long on pilot when I was loading on a big pile of coals and loading the firebox clear full last January during that real cold snap...and even had the firebox high temp alarm go off on that one!hmm so its going to get a better draft as it gets colder?No way I would take it out! You will need it this winter. When its real cold out mine can't even keep up...its wide open and draft is still too high (at times)...that's why I put a manual damper in after the baro...take the edge off the draft so that the baro can do its job properly. (keep up) Just to be clear, this only happens (for me) when its 0 or below and maybe when the wind is just right...just keep the baro covered with HD foil if you don't need it...easy to pop off when its needed then. Or if you don't like the foil look it would be easy to make a sheet metal "cap" that just hangs on the front of the baro...paint it black, you'd never notice it.
Yup.hmm so its going to get a better draft as it gets colder?
ok I'll just leave it with the foil for now and if I see it too high I'll remove it.Yup.
A chimney works because the warm air column inside it rises...the greater the difference between the flue gas temps, and the outside air temps, the higher the "draft speed" (air speed in the chimney)
So how was the house temp after all this?I still think it seems to be working well imo
I totally brain-farted on it actually getting colder than it is now.
its been 72 pretty much all day including now Ive been making a list of things that can be improved in the house. Its pretty big but I'm going to start with all new door seals and fix broken latches on windows.So how was the house temp after all this?
Ok I'll get one then I wanted one for a long time anywayI'm happy enough with my Seek, its not fire department quality equipment, but does the job for DIY projects just fine I feel...take those reviews with a grain of salt, some people would gripe if they were hung with a new rope!
The master Bedroom is 75 but its the best room heat wize in the house always has been.
There is two dampers on the duct work to do that. Ive been slowly adjusting them for the new furance.Can also work on directing the temperature throughout the house. Personally I like sleeping in 68f room. The extra heat can be directed to another room ideally with less heat loss to act as a sink.
While it doesn't really matter if the BD is sealed up, or gone entirely, I'd be tempted to think that if it's only getting a slightly high draft at startup, a BD isn't really needed. Of course, you'll want to watch as the temps change with winter, but with your outside stack, you might not see an increase in draft when it gets really cold. I'd love to eliminate the BD if I could, and I threw in some just plain wrong features when I ran my stovepipe, because I already knew I had some excess draft to knock down. It wasn't enough. The BD is always open, and I'm currently working on cobbling up an outside air supply for my BD as I can't stand the notion of it sucking the warmest air in the house (next to the furnace) up the pipe 24-7. I'm not telling anyone to do this, and Lammpa already told me not to do this, but I'm a big boy, and I'll deal with my mistakes - if it turns out to be one.I don't think so the most I've been getting is .06 when it's on 1 with tin foil over the BD. The only time it really needs the BD is when it's starting a fire from nothing. I went all out on the chimney I don't know how I can get anymore?
If I woke up to find that it was 75 in my bedroom, I'd probably be 2/3 of the way through 9-1-1 before I came to my sensesThe master Bedroom is 75 but its the best room heat wize in the house always has been.
!I don't want to derail this thread, but since Gary already has some experience running this thing flat out, and all the Kuuma performance folks are gathered round, I'm going to ask:
Does anybody find the thermostat controlled high blower setting to be useful? For me, it seems like that just causes the stove to cool too much and cycle the fan - accomplishing nothing, really. It's still the same amount of heat per hour.
