How is a Drolet heat commander supposed to work?
As long as flue temps don't get too low, start gooping the chimney up at the top...
I actually have a question on that. Since I have a barometric damper, it seems like it would be impossible for my flue temps to be very hot as I'm always mixing in a healthy amount of room temp air. One thing that everyone has always said about the HC and kumma is that they leave the flue/chimney extremely clean. I always assumed that was because the creosote gets burned with the other gasses in the fire box. I can visibly see the smoke burning when I'm looking up at the aux air tubes, but if I lift the barometric damper a little, I can still see some smoke going through the flew, and I can obviously see it coming out the top of the chimney. I'm not saying that its not a lot less than with the old unit (haven't paid enough attention to say that), but when I peak down the barometric damper, I DO see a fair amount of build up on the remaining horizontal section of the flew (after the damper).
I was assuming this was because my G draft isn't working right yet, but I'm not actually convinced of that based on what everyone is saying about how it works. If its supposed to be closed during the majority of the smoky burn phase (as opposed to the charcoal burn phase), and its pumping in more oxygen because its cycling, it seems like my fire would burn hotter and there for cleaner. I supposed the extra oxygen coming in from the bottom could also reduce the oxygen coming in through the P draft and Aux air tubes, there by reducing the amount of gasses getting burned before exiting into the flue which would explain the increased buildup. Ugh, always something to be confused about...
As a new development, I noticed last night that my blower isn't actually kicking on. I'm going to pull one of the RTD connections off its terminal in a little bit to see if it will still kick into high when it detects an over heat. If it does, I may try running it at a different speed other than the standard low speed. Can anyone tell me which wire goes with which speed. I think I have the low speed written in my notes from a conversation with their tech support, but I don't think I have the others.
They are sending me a new CPU board, but they don't have any in stock in the US, and they only send shipments down from CA every 3 weeks or so, and they have to go through customs. IE it will probably be late Jan before I get it, but could be a little later.
The extra air coming in the G damper would indeed make it burn dirtier...wood burns cleaner with air over fire, rather than under. Old wood/coal stoves often had the ability to change if it was air over/under based on which fuel you were burning...coal doesn't like air over at all.
Are you seeing creosote, or dry soot? I recently checked the Heat Commander flue, which my sister is using now, by sticking my hand in the baro and feeling around...it was just dry dark grey to black soot powder...but she is FINALLY, after all these years fighting it, burning very dry wood.
Once you get it working as designed I think you'll see the flue clean up some...but there will always be a little buildup from cold starts/etc.
Reactions: salecker
Both actually. I see a lot of dry soot behind the baro damper, and I'm guessing I'll find something similar in the chimney but I haven't climbed up on the roof to look yet. Might do that tonight. Looking through the baro, I can also see a bare spot on the chimney liner and it has a layer of creosote on it. Not thick, but its definitely there.
I think you are 100% right on the G damper. I started splitting most of my wood in half again before loading it, and that has made a big difference as well. Furnace gets up to temp a lot faster and stays there longer. Once everything is finally working, I think my only complaint will be the flat bottom of the fire box. With the grate in the center, it would have SO much nicer if there was at least a slight V to the bottom to direct the ashes and coals towards the grate.
We had low temps below zero for a couple of days this week. Even with the blower not working, and only having the 6" duct feeding into the cold air return, the HC kept up pretty good. I loaded it at 10pm, and I don't think the NG furnace kicked on until around 4am, and even then the NG would only run once every hour or so while the coals were burning down. If the G grate was working right, I don't think the NG furnace would have kicked on at all. I loaded it again around 7pm, and again around 2pm. High temps were in the single digits and sunny, but the HC kept the house a comfy 71 deg all day long. Once it got back up to temp after the 7am load, I don't think the NG furnace cycled at all until well after dark.
New CPU finally arrived from Canada. In the mean time, my blower motor also quit. It acted like the starter capacitor went out, but since they use one that's hard wired into the motor, they had to send me an entire motor. It arrived the same day as the CPU. Installed both over the weekend. It was up in the 50s, so I hadn't been running it much last week. Fired it up last night and everything appears to be working correctly now. Finally get to see what it's going to be like for the foreseeable future (I hope).
Definitely feels like a brand new furnace! As opposed to one that's 3 months old that is :) Its nice to see the unit actually work like everyone on here says it should. This entire time, I think the only time the blower kicked on was when the RTD temp was over 190. Now it kicks on shortly after adding wood, and will often run when there's only a relatively small amount of coals in the fire box. The blower actually runs a LOT more than i originally expected that it would so now I'm curious how people are using theirs when the weather's a little warmer. I have the HC Tstat set down around 60 deg at the moment so its not calling for heat. The blow is only running (at low speed) to to keep the system from getting too hot. We're warming up to day and its going to get back up to 50. I added wood at 11pm last night but didn't really notice that the weather was going to slowly warm up over night. It was 36 at 5am, but the house was a toasty 71. Any warmer and my wife would have probably started asking why the house was so hot. I'll put that in a new thread though. Thanks to everyone for the help and information!
Gosh this thing does keep a steady temperature, even at -20F!
  • [Hearth.com] How is a Drolet heat commander supposed to work?
You would think that at -20F it would be difficult to maintain a comfortable temperature but I have NO problem whatsoever. I was just burning ash and easily held 70 degrees. I did start to build up a decent amount of coals but still produced hours of heat without having to relight.
Eric
