A stove that delivers 30k BTU’s per hour for 8 hours shouldn’t need a blower to get the stove room to 70 in a well insulated smallish home.
The question is whether it is delivering 30k btus into the room or up the stack but I agree that if those 30k were released into that well insulated 1500 SF it should be quite warm.
But that argument seems inconsistent with what I understood to be the case: that at high burn rates the majority of heat is *not* produced in the cat; it's produced in the primary burn. I.e. there is not much cat food produced because stuff is burned in the firebox, because that combustion is more complete.
Burning oily evergreens at high burn rates can overwhelm primary and catalytic combustion processes and result in visible smoke. When this is happening I would expect the cat to be quite hot unless there is a cooling effect from the unburned fuel. Imagine a very rich running gasoline engine which is something car makers actually do to cool the combustion chamber and reduce NOX emissions.
I just looked at the BK page and it lists this as just a 2.3 CF firebox. That small size is not the problem.
! And if it’s not in stock you just accept that it is not in stock
