It’s very shrouded for sureIt's a 2.4 cu ft box, if I remember correctly.
Is it more shielded than the Chinook?
Ifn othing is wrong with the setup, that might have to be it.All ceilings are 8’
I think I’m dispersing the heat very well and it’s just not able to put out enough heat to keep the whole house warm.
I only have 1 ceiling fan and it’s in the master bedroom.
I have a wall Mount fan that points down and away from the stove room and that fan is just about at the ceiling.
I’m sure if I turned off the fans abd let the heat stay in the stove room it would get incredibly hot in there
I can for sure. But I hill every inch of that stove usually and I load them north southIfn othing is wrong with the setup, that might have to be it.
Im still puzzled by the speed with which you burn down a full load.
Can you post a pic of a full (re)load before you close the door next time?
This might be like trying to heat with a zero clearance fireplace or flush face insert and no blower. Hopefully things inside the stove shell are designed to be run safely, though obviously less efficiently, with no blower.It’s very shrouded for sure
What problems could be caused by not having a blowerThis might be like trying to heat with a zero clearance fireplace or flush face insert and no blower. Hopefully things inside the stove shell are designed to be run safely, though obviously less efficiently, with no blower.
Not saying the boxer is designed this way but if the manual requires the blower then things might get hot enough without the blower at max output setting to melt things.What problems could be caused by not having a blower
Hmmm. Ok.Not saying the boxer is designed this way but if the manual requires the blower then things might get hot enough without the blower at max output setting to melt things.
Hard to imagine a reputable stove company designing an appliance so dependent on electricity. Hopefully output just goes way down without the blower. BKVP will surely know.
Blowing through 2.4 cf of Doug fir in 4 hours and not getting heat in the room means that heat is going somewhere else. Gotta be up the stack and that chimney has limits.
Yes, an E/W loader is limited due to concerns of the wood falling against the glass. Note that Doug fir is not pine. It is a higher BTU wood that falls in the 19-20 BTUS per cord range.If you're getting 2 cu ft of pine in there, and I assume a low of 15 million BTUs per cord
Yes,.my calculations were meant to give a lower limit to the BTUs put into the room. And that lower limit adds up to 41,000 BTUs per hr.Yes, an E/W loader is limited due to concerns of the wood falling against the glass. Note that Doug fir is not pine. It is a higher BTU wood that falls in the 19-20 BTUS per cord range.
Firewood Weight and BTU Chart (160+ Trees) - Theyardable
Please note that the table describes the average volume of one net cord's weight, which in this case is 85 ft3 (a stacked cord of wood)theyardable.com
Is the cat probe still reading active, or is a cold/dead/stalled stove? Not unusual for anyone to stall a BK, just mark the dial, and never go back to this point (or below).If I turn the dial below half way the fire goes out and I’m left with unburnt logs in the morning.
Due to the E/W loading, the actual loads are probably closer to 2 cu ft. It's another reason why I prefer a N/S loading stove.There got to be something wrong with the stove if it can blow through 2.4 cu ft of wood in 4 hours especially if it has a BK thermostat. It would be very interesting to see the internal flue temps or even an external pipe temp.
I'm glad there is progress being made. As to why the lower air is working better, doug fir has a high oil content and can burn quickly. Perhaps the high burn rate was actually exceeding the cat's capacity and blowing a lot of heat and unburnt flue gases up the flue. This would be similar to Pointdexter's experience burning too dry wood in his stove.
Thank you. My local dealer said it would be a few months to get a blower. Is there any chance I could find one sooner?The dual blowers make a difference. We tell folks the Chinook, Ashford, BX24 and 3 insert owners benefit from the blowers. Generally people report they make a tremendous difference.
Try eBay. A few dealers will sell misc parts. But if they don't have it in stock, square one.Thank you. My local dealer said it would be a few months to get a blower. Is there any chance I could find one sooner?
To push the hot air trapped between 2 metal surfaces, the blowers help.A stove that delivers 30k BTU’s per hour for 8 hours shouldn’t need a blower to get the stove room to 70 in a well insulated smallish home.
