Interesting. The lever on my unit, when closed, covers the primary air hole 100%.The primary air on modern stoves does not close down 100%. It will always admit a little air, this is to prevent smoldering the fire.
Wish my Drolet insert did that. But since yours has the boost air the effect is the same but yours is easier to plug. My boost air is on the air control plateInteresting. The lever on my unit, when closed, covers the primary air hole 100%.
I see, had to look this up. It is interesting. The new air intake design is different from what was standard on PE stoves for decades. I installed a 2020 PE T6 a couple of years ago. I will have to see if they will let me peek under the ashlip to see if this is for all the large firebox PE stoves, or just the insert. This has my curiosity piqued.Interesting. The lever on my unit, when closed, covers the primary air hole 100%.
Understand. Just trying to anticipate colder days and what she may do and have a plan in place.The EBT is self-regulating. I would leave that alone unless absolutely necessary. It's best to not tinker too much with the stove. There is a risk of adding too many variables which can lead to tail chasing if there are issues. The Summit is a robust burner. Work with it for this season and get to know how it performs under all conditions.
Thank you for the reply. I'm just thinking ahead to when I have a full load on a cold day. The smaller test fires I had drafted at 0.16 to 0.18, with a requested limit by the manufacturer at 0.1. this was with the damper closed and boost air blocked. So I've already changed the mix of primary to secondary by having a llmore secondary flow than primary with the boost air blocked. I'm assuming blocking secondary would bring it back into balance and help with the draft being over spec.Well with the ebt2 you could reduce the total draft of the system and never actuate the ebt regulator flap. Same I guess could happen if you just blocked the secondary air intake. One might be able to use your damper and be able to hear the flapper close. Open the damper the flap should close??? Just guessing. If it doesn’t close maybe it’s been blocked too much. I found it difficult to keep the appropriate primary :secondary ratio. I would target lazy secondary fames at the last 1/3 of my burn cycle. They probably should still get a bit blow torch like under a full, hot, high (but still normal) draft burn.
Edit… is it time to start thinking about restrictor at the top of the liner? It would help keep the primary/secondary balance
Thank you. My education continues....Regarding the secondary flames, different from the tube jets, I would go out and look at the chimney. Clearly you are burning gases. But are you burning all? Do the old "can I see smoke" test - for (chimney cleanliness) safety.
It's a design choice where most Canadian designers seem to favor making their stoves perform well in single-story homes. Some American-made stoves have longer secondary air intake paths with 90º turns that require stronger draft. They tend to work better in 2 story homes but often need a 3' extension on a single-story chimney if it is only 12-13' tall. This is a generalization of course. There are exceptions.I really don’t think inserts on a two story 6” liner is that out of the ordinary.
Thanks @begreen .I would let the EBT do its thing. There will be some fountains of fire coming below the baffle during peak burn. That is because the wood is outgassing strongly and the stove is working aggressively to burn off the volatiles. This is by design and only lasts for about 30-45 minutes. After that, the EBT flap closes and a more gentle billowing of secondary flames continues. 350º on the stove face is a bit cool. Don't be afraid to take it up hotter. It's a robust design.
Is the EBT flap open when the stove is cold? Is the manometer reading a draft of .16 after an hour or two into the burn or does that number decline by then? If it is just reading high at the peak of the burn then I would say it's doing its job
With the EBT door unblocked, the draft remains at 16 or slightly higher for hours.Is the EBT flap open when the stove is cold? Is the manometer reading a draft of .16 after an hour or two into the burn or does that number decline by then? If it is just reading high at the peak of the burn then I would say it's doing its job.
3/4 load today, raw rainy day. Draft at 0.1, primary air 100% closed, exhaust gas temperature cruising at 850ish, face temp above door averaging 500ish.Is the EBT flap open when the stove is cold? Is the manometer reading a draft of .16 after an hour or two into the burn or does that number decline by then? If it is just reading high at the peak of the burn then I would say it's doing its job.
![[Hearth.com] Initial Draft Readings for Pacific Energy Summit LE Insert - Cause for Concern? [Hearth.com] Initial Draft Readings for Pacific Energy Summit LE Insert - Cause for Concern?](https://www.hearth.com/talk/data/attachments/301/301325-6671b908b80a199245982d476b54c3a0.jpg?hash=V5vOWTDQKw)
Draft was holding at 0.1 and temp slowly dropping. Just guessing that temp was 750. Pure guess. Plateau was 850ish.What was it reading 1 hr later?
