Yea blocking the primary more will pull through the secondary more which would cause even higher secondary burn temp and robustness. From my understanding you’d have to do the secondary first then adjust primary. But obviously you’ve already got it figured out.Adjusting the primary only still resulted in above acceptable drafting limits. The unit just drafted through the secondary.
![[Hearth.com] Initial Draft Readings for Pacific Energy Summit LE Insert - Cause for Concern? [Hearth.com] Initial Draft Readings for Pacific Energy Summit LE Insert - Cause for Concern?](https://www.hearth.com/talk/data/attachments/305/305954-a5636dc202822354fe663cab0ba72e84.jpg?hash=4GBRG5Nhs2)
