- Dec 31, 2006
- 74
That's funny and probably true. The stove is heating up to around 600 degrees. Problem is, very little of that heat is coming inside the house.
BrotherBart said:Roospike said:BrotherBart said:Just hanging out on the side listening in. Summit that won't heat. Can't be, can't happen.
Just keep hanging out BrotherB , its not that the Summit is not heating, its acosta2269 heating the state and not the house. ;-)
Gotta be brother.
acosta2269 said:Hogwildz, how are you?
Standing in front of the insert is not extremely HOT. It blows warm/hot air out, since day 1, which is why I started this mess.
The stones on the face of the chimney are not hot. They are slightly cooler than room temperature.
How do I know if I have a Heat-a-lator fire place? How can I find out what "type" of fireplace it is and how those vents are being used? Is that something that the building dept would have on file in the house plans?
We had small snow showers here the last few days, problem is, it won't lay here. I think the Summit has a several square mile heating radiusRoospike said:BrotherBart said:Roospike said:BrotherBart said:Just hanging out on the side listening in. Summit that won't heat. Can't be, can't happen.
Gotta be brother.
We have a few Summit owners here on Hearth.com that are from NewYork , now you know why New York hasnt had much snow.
He DID NOT install a block off plate. Rather, he stuffed the top “nice and tight” with insulation. He said that was “better” at avoiding drafts and keeps the pipe from moving.
Hogwildz said:I would demand removal of that fiberglass insulation & installation of the block off plate. Block off plate is stated right in the manual! Either at damper area, or seal around surround (tightly), if its stone you'll never get it to seal tight. I'd demand a damper blockoff plate.
BeGreen said:Now I would really want to know how the installer connected the OAK and if any other corners have been cut here?
The outside vent at this point is a complete mystery. If it's venting the stack, that would lead me to wonder if the chimney is brick or just a brick veneered chase. Is there cool air coming from the interior hole on the upper side of the fireplace? Or if you hold an incense stick near it, does it draw air?
Roospike said:Alright , freestanding Summit , front temp 490° , thermometer 12" away , blower on medium , temperature 178°
Not an insert test so it will differ but 105° difference ?!?! I think the insert blower temp should be warmer then a free stander.
Are you sure your Summit is not set on A/C mode ?
