I am learning a lot from this thread.
It seems that the amount of chimney draft is very critical. Is this a requirement for a gasifier type boiler? I have an old style Tarm MB55. It seems like the only requirement from the manual is an adequate draft—-a minimum chimney height of 20 Ft. They don't mention anything about too much draft. My chimney is 27 ft. I only have a "paddle" damper in the pipe between the boiler and chimney. The main air control is the air flap on the bottom of the ash cleaning door. This is controlled by a mechanical Samson draft regulator that maintains boiler temperature. Does this type system not have an upper limit on the chimney draft since it is a very simple air tight design which just keeps a fire going in the "big barn". Just curious.
John M.
Hi John, yeah I don't have as much back ground in the boiler side of things, but I'm sure limiting the draft speed to a certain level would do nothing but extend your burn times, efficiency, and overall life of the boiler. I looked at some of those Tarms years ago...and I'm almost sure I remember seeing barometric dampers on some of them. A manual damper like yours could work too, bit IMO you really need a permanently mounted manometer to measure the draft for consistent results with setting the damper.
The only thing bad about a manual damper is if your unit is able to open and close a draft damper on the firebox automatically, then that could cause trouble if you had your manual damper closed too far...the effective draft on the firebox would drop too low and you could have smoke back into the house...a baro eliminates this issue because it self adjusts to allow for changes in the firebox, gusts of wind, etc.
All solid fuel fired appliances can be overfired if is draft too high...doesn't matter the brand/style, they are all made of some type of metal, and metal can only take so much heat. Some units have insulated fireboxes, but even those can be damaged with too high draft if the fire is drawn outside of the firebox or burn chamber...anywhere other than where it was meant to be.
And as I said, draft affects efficiency, for several reasons, but one of the main reasons is time for the flue gasses to transfer heat to the furnace/boiler. Think of it like a hot potato...if you hold it for a split second you may not get burnt...hold onto it for longer, the more the heat transfers, the worse your burn is. Same for flue gasses in your heater, the more time they have to contact the surfaces of the heater, the more heat to your house potentially.
The higher your draft level, (sometimes referred to as draft speed) the faster the flue gasses are being pulled through the heat exchange area of the furnace/boiler.
Boy, that ended up way too long!
Maybe
@maple1 has some additional boiler applicable insight here...
