I have read the manual. With that said, the original release of the manual last season was a copy and paste from their previous stoves, which operate different from the newer style stoves.
The last time I added the baro damper, things did not end well. Therefore I am moving forward with caution and trying to operate the stove per their feedback even if it goes against all logic. The last thing I need is to go off on my own and have them tell me good luck, we tried to help. I also don’t want to tell anyone making good suggestions that they are wrong either as everyone here is only trying to help and learn so they can continue to help.
So far this week, following their suggestions...
- Distribution blower kicks on shortly after initial load or reload and stays on until all fuel has been burned and the stove is down to hot ambers. When the stove is down to ambers, the distribution blower cycles.
- Loading the fire box for the over night at 11pm results to the first floor hitting high 80’s at around 2 am and the fire box down to very small ambers at 7am. At 7am the first floor will be 71 degrees. Only complaint here is I should be getting a longer burn time and perhaps not so much of a spike of heat.
- No matter if it is 20 or 30 outside, the first floor quickly rises to mid 80’s with ease and the second floor maintains ~71 degrees, because the first floor is so hot. This happens even if I reduce the amount of fuel per load. Yes, shorts and a tee shirt is a must.
- Stove pipe looks like it is burning off the build up of creosol. Here is a photo of the inside of the stove pipe yesterday. I am assuming the flake off is from the previous state of the build up of creosol?
Assuming this is starting to look like cleaner burns?
