Great. Now if you could just send me a money gram I'll get that all taken care of for you.I'll take two![]()
i will also post the response once it is received.
Tundras new big brother...Heatpro
OK, here's the deal. I am very busy preparing for my year long transfer to outer Zimbabastan for work. I generally use LNM freight and they happen have a location near you. I will send you a check for $25,000 to cover the furnaces, the shipping, and a lil sumpin sumpin for your time and trouble. Would you mind taking care of these details for me as I am very busy right now. Oh, and if you don't mind, could you ship the furnaces before cashing muh check...?Great. Now if you could just send me a money gram I'll get that all taken care of for you.
Hmm, didn't really think about it much, I suppose we otter do a separate thread to keep this bad boy at least a lil bit on topic. Actually, this is probably a good start right here https://www.hearth.com/talk/threads/drolet-heatpro.145332/Are you going to start a separate Heatpro thread, or merge with Tundra/Heatmax for now
You can use an inexpensive manometer. Most wood burners like the Dwyer Mark II to measure the chimney draft, which you will want to do regularly if you have a barometric draft regulator (which I'm not seeing...how tall is your chimney again?) Anyways, you can use the manometer in reverse to check and set SP too. If you need to get one, check the "for sale" forum here...there is a good deal on 'em thereTrying to get someone to come over so i can measure the static pressure in the supply ducts
Good lookin install there builder! You are probably chompin at the bit to make that thing blow smoke no?!![]()
https://www.hearth.com/talk/forums/articles-for-sale-wanted-etc.10/Can you link me or provide a picture to the manometer you speek of i can't seem to find the forsale section on here.
Yeah, that's true, but, if you are burning dry wood and are running the Tundra correctly, and maintaining your chimney, I'd say the chances of a chimney fire are pretty minimal. Most wood furnace manufacturers call for a baro, or at least they do if you have high draft. And I'm bettin your 24' internal chimney is gonna draft real well! (that's almost the ideal chimney BTW)I did not install a barometric damper due to some reading i have done on it. Its to my understand that if a barometric damper is installed and you have a chimney fire that its like putting fuel on the fire
To give an idea of cost to anyone thinking of installing a Tundra furnace here is what i have roughly invested in my setup.
Tundra Furnace= $1460
Chimney Insulated and black single wall = $1400
Controversial Cement Blocks = $20
Ductwork= $950
Electrical = $75
Material Grand Total = $3905
Labor i would figure about 30 Hours for items listed above. Cost will vary some depending on location but i think its fair to say that a range of $1000-$2000 is not out of the question.
Labor and Material Grand total = $ 4900 - $5900
Hope this helps anyone thinking of putting in a Tundra trying to figure out the real world cost of it.
Yes sir, it adds up quick950 for ducting ? Yikes
I have sent SBI an email about my Tundra. Due to me having learned about the cracking issue from Hearth.com and not SBI i feel it is only fair to keep you guys/gals informed about my current questions and answers with SBI.
Here is a copy of my email to SBI and i will also post the response once it is received.
I purchased a Tundra on August 24, 2015 roughly 2 months ago now. I was aware of the cracking issues prior to my purchase. So before my purchase i called you "SBI" to make sure everything had been corrected. I was told Yes it was. I also asked if the units that were currently available for purchase were good to go. Again the answer was "YES". Now after doing some more research online i find out that the new Tundra units have firebricks lining the front of the furnace. I can assure you that the unit i have Serial number ( 1993) does NOT have any firebricks lining the front of the unit. It is to my understanding that now SBI has a kit that includes firebricks for the front of the furnace.
My questions now are as follows.
1)Is it OK for me to use my Tundra in its current state with out worrying about cracks?
2) Will SBI send me the "KIT" which contains firebricks for the front of the firebox?
3) Is the additional front firebricks how SBI corrected the cracking issue?
4) If SBI is going to send me a kit how would you have been in touch with me if i did not send you this email.
5) I did register my Tundra with SBI why was i not sent any information about this?
The list of questions could go on. I do not regret my purchase of the Tundra i just wish SBI would have been honest with me when i made my first phone call to you asking if all issues had been resolved and if all available units currently being sold were corrected. Due to the lack of the firebricks in the front i take it that my unit has not had the repairs done to it to prevent cracking from happening.
I am not trying to be picky just helping out. If you are getting an inspection done i don't believe the wiring will pass. The Romex should be shielded in conduit.
Have fun with the duct work i know i didn't. That is one thing i never liked doing. Did your unit come with firebricks in the front? What serial number do you have on your unit?
