Buzz Saw
Not around my area. Menards employees are the least helpful that I deal with. Ah well. Back to burning wood.Einsteins compared to Lowes and HD though...and much less attitude
Plenty of room!I had 2" to spare while backing up
How'd that go? Short stack make for a weak fire?I did the initial fire outside
UNGH UNGH UNGH! (that's my Tim Allen-Tool Time grunt)Used my best helper to get it down into the basement
Plenty of room!
UNGH UNGH UNGH! (that's my Tim Allen-Tool Time grunt)![]()
? They're changing something with the damper?new parts (bricks and front damper)
Likely you will be fine now. Sometimes you have to get the rod that opens the damper, seated into place properly after moving the unit. A few people have had to tweak the rod a bit to get it to work smoothly, take the cover off the box on the back where the damper motor is to check if the rod is working smoothly back there too. Not binding at the pivot or rubbing on anything. I have heard of some people that lubed the pivot points with a dab of high temp grease too.Can someone fill me in on the "sticking issue" with the front damper? The reason i ask is when i did the initial fire outside and i was playing with the switch for the damper i did notice that upon closing the switch i didn't notice the damper close so i gave it a light tap and it finished closing on its own. So i tried it a few other times and had no more sticking issues. Any info that could be provided would be great.
Also the V-bend end of the control rod where it meets the damper arm would occasionally bind holding the damper slightly open. Opening the V of the bend slightly took care of that.
Bring it!I hope i am keeping this thread on track
Hey @bedrock1 , how's it goin? Still fightin this huh?hi guys what u find the drolet tundra/ heatmax like for heating your homes, last year I could not get mine to heat a 1000 sq house. I found out they change the thermodisc from the rear of the furnace to the top, I was burning a lot of wood to get the blower to cut in , now I have the kit on top I find the blower is still in but just blowing cool air when it should be cut out.
I tried pushing the unit over once i had it on the blocks. Didn't want to move at all. I did thinset all the blocks together along with the first row of blocks to the slab.Yep, great post @Builderml . Nice clean installs are always nice to look at.
I agree it would be nice to have it up that high--also an advantage when cleaning out the firebox and burn tubes in the spring, what a pain in my furnace lower to the ground. One thought on the blocks--It looks like it might not take much push from the side to tip them over. I know the furnace weighs a lot so it's probably unlikely but the width vs height of the blocks isn't in your favor. I also have a tendancy of overthinking things...
Also, how long are those 8' runs? I think you mentioned in a different thread but I have trouble keeping track.
Keep the updates coming, thanks for posting.
1-8" run is about 20-25' plus the branches that come off of it. 3 branches
The 2nd 8" run is about 40' plus the smaller runs that come off of it. 4 branches
I did install all the take offs with dampers just in case I needed to make adjustments.
Good point. Steel can slide on a smooth concrete floor pretty easily reallyThe impact required to knock the stove off the blocks would damage the stove/furnace even if it was right on the ground.
I want to see this diagram.. Is she hot ?Ok, I'm a geek so I drew up a free body diagram** of the forces involved and calculated it would take around 125 to 275 pounds of entirely sideways force on the furnace to tip over the blocks, depending upon where on the furnace you push. It would probably take even more than 125 lbs because you thinset the blocks together and because your ducts may help resist movement. I estimate that I could probably impart 275 pounds of sideways force if I sprinted and crashed into a broken heap on the side of the furnace. So you should either place hurdles around the sides of your furnace, or else just don't invite me over. Beyond that, I reckon your chances of failure are quite low.
Or you could just listen to the other guys above and get much better advice much quicker, which I'm sure you have figured out by now.
**And, the "free" part of free body diagram refers to the manner of evaluating a body diagram, and does not refer to the cost of the body diagram. But in this case, notice that I did not charge you anything for this advice, and we all know that advice is worth what you pay for it.
Ok, somebody post something useful to compensate for this derailment...![]()
