I want to see this diagram.. Is she hot ?![]()
Are we still talkin about Tundras?Surrounding it with those cushy shiny posts & velvet rope things like they used to have for lineups at the bank might work.
Eww...algebraThis is probably quite disappointing. Overly simple analysis that doesn't account for many factors. And it doesn't show much skin, either.
Wf is weight of the furnace at a given location on the blocks, which are 8" wide.
I wonder if you applied that same force to the top of the furnace, would it tip over as well?
all I could do just to try and tip it on it's side
Eww...algebra
Hey, any of y'all had to replace your Tundra/Heatmax door gasket? I wondered what density of gasket it is?
I see the parts list show it as a 3/4" x 7'...
I don't know what it is. I just know I don't understand it. I'm jealous. I wish I did though.that's more like physics/statics.......![]()
Still algebra, no?![]()
Using your formula i come up with 160 lbs i am using 16 not 13 so 16/55 X 550 = 160LBS ..I have no reason to question your formula, i'll be darn if i can remember how to come up with the formulas its been over 20 years since the last time i was sleeping in class. Looks like i need to install some 200mph duct tape. The reason i used 16 is because the center of the furnace leg is on the center of the block not the outside edge which widens my base.Hmm, the plot thickens... Good call, @Highbeam , I think that's a more accurate analysis, and unfortunately more dangerous. This shows the realistic case where the far side block tips along with the furnace. Moment arm of the applied force is 55 inches above ground (furnace plus block heights), and moment arm of the furnace weight is only 13 inches (half furnace width).
This suggests the furnace will tip at 130 lbs exerted sideways. Push at an up angle and less force will tip it. Also, push on the front corner and it might not take much to tip because now you're twisting the furnace about a vertical axis, which might help get things going. The connected ductwork should help resist, but I don't know how much.
So, the bad news is that the furnace will tip with much less force than I previously thought. Astute observers may note that the same analysis above suggests the rest of us with furnaces near the ground could tip them with only a little more at 183 lbs (39" high / 13" wide * 550 lbs).
This may be true, however furnaces on the ground are still harder to tip over because the center of mass raises higher (requires more energy/effort) in order to exceed the threshold that tips over vs. falls back home. Also, if a furnace on the ground does tip, there is 16" less inches of potential energy to cause damage to anything that might have a chance at survival.
Point is, I'm a bit leery again, and I'd wager that I could tip it over on 16" blocks with a smart shove in the proper location/direction.
I like a good analysis on paper, but real-world results are more important, and your example seems pretty hard to argue with.
Sounds like a good job for a crowbar and a chunk of 2x4. But we're glad you didn't otherwise you wouldn't have the above example!
What I was getting at is that whether the furnace is up on blocks or setting right on the ground, a similar force is required to knock it over. Following that, the additional risk caused by putting your furnace up on blocks is negligible.
I don't think so - the higher it is, less force that is required?
EDIT: But it also might depend on how or if your furnace is attached to the blocks.
EDIT EDIT: Yes, most definitely. I think.
Someone should tell SBI right away that it is going to probably have the same cracking issues because they didn't put firebrick in the front again.Tundras new big brother...Heatpro (broken link removed to http://www.drolet.ca/en/products/wood/furnaces/extra-large)
(broken image removed)
It does appear that way. Surely they are not dumb enough to go down that road again. Of course the PSG Caddy line has no bricks there and they are fine. There are quite a few changes here from the Tundra so I'm sayin they are figuring it's handled. Pretty cool plenum...because they didn't put firebrick in the front again
It does look like a nice furnace. Unfortunately I won't be one of the first hundred to own one this time. I'll wait until they sell a thousand before I decide so they get the bugs worked out if there is any.It does appear that way. Surely they are not dumb enough to go down that road again. Of course the PSG Caddy line has no bricks there and they are fine. There are quite a few changes here from the Tundra so I'm sayin they are figuring it's handled. Pretty cool plenum...
I'll sell you a preorder for $10,000They show a sku # for Menards, but that # doesn't come up when searched on Menards site...as of yet. I wanted to see the price
