12" long...OK I'm I missing something here. Manual says. First vertical start off pipe no less than 12". The start off adapter is 8". Don't tell me I need an adapter for my adapter!
They just don't want you to install an elbow directly to the take off collar.OK I'm I missing something here. Manual says. First vertical start off pipe no less than 12". The start off adapter is 8". Don't tell me I need an adapter for my adapter!
Exactly, hot air likes to go up, but not as much sideways, unless it has some "momentum" firstMakes sense to allow gravity flow in a power out situation.
Duh.. I feel kinda dumb! Lol. Probably won't be the last time either.
Understood. How far do you have to go?Brenn...just trying to come up with the least expensive way to do the duckwork. Next year I plan on having all ductwork redone. So both gas and wood furnace are tied in together. Thought if I could utilize 6" I could then reuse.
Well, I guess technically you could. It's 8"?Menards has a metal flexable duct with operating temp of 435 degrees. Is it possible to use this?
About 2 19' 8" runs. Then on one side about 4' to register and the other about 25' to 30' for the other registers.
It's not gonna flow as well as steel duct but if you can keep it a fairly straight run and run 8" almost the whole way...not ideal, but it may work for temporary. Is it really that much cheaper?
When you put pencil to paper, add up everything, elbows, pipe, adapters, connectors, hangers, screws, clamps, dampers, registers, etc, is it really that much cheaper than going with standard round duct? I would be worried that I'd spend that money (saving a couple bucks) only to find it really doesn't work right...I dunno, not saying it won't work, just a risk is allYou can get 6" or 8". I think I'll use the metal flex 6" to the short runs to registers. Then use non flex 6" to long registers. It's a little cheaper. You get 36 more inches for about the same price on the 8" round.
Man I've change my mind everyday on the ductwork planning. I think the wifey is getting tired of me buying stuff at menards! Lol
If you look at the manual on many wood stoves, often they call for 2' of vertical stovepipe before going horizontal to the chimney, same principle
I just went to the "contact us" tab on the SBI website and stated my questions. I think it was last Friday or Saturday i sent the email to them and i had a reply Tuesday,. I was in contact with the customer service manager. SBI did ask me to provide proof of purchase to update my file so i sent them that also. I would expect you should hear from them soon. Mine are suppose to be shipped out Oct. 26.Question for those who have contacted SBI and have been promised firebrick for the front- is there someone specific you've been in contact with? I've emailed the [email protected] address a couple days ago asking about the "kit" and have yet to hear anything back. Would like to update both my Tundras and if factory parts are available....
Builder your right.....ductwork = NO FUN!
Double...lol....had me laughing.... And thanks!
Took me a bit to find this...it's Tundra II and Heatmax II, I only see one version of the Heatpro. (EDIT: Ooops, I see I misread the original post, I thought you said there was 2 versions of the Heatrpros too.)Not sure if this is new info or not but i figured i would pay SBI website a visit and check out the Heatpro specs and while i was there i noticed a new to me Tundra II and Heatmax II. To me it looks like the same units with the same plenum they have on the Heatpro. Sorry folks but that plenum is going to be one heck of a cluster **** with all those outlets.![]()
I received my response from SBI. I told you i would keep you guys informed so here goes.Talk about keeping it short and sweet. Drum roll ---The response is. " The firebrick kit will be shipped out October 26 ". None of my other questions were answered.
Here's where I found it...I might be dense but I can't find them. Very curious.
