Hi all-
We just installed a new (Manufactured 12/21) Englander 32-NC to replace our sadly split-at-the back-seam Fisher Mama Bear. The Fisher was here when we bought the place, and we've burned her for 10 years, now. Sadly it has a split seam in the back that needs repair, and that will take some time to get welded. So we thought we'd go green and buy an EPA-approved appliance.
We're not know-it-alls, but we have grown up with wood and coal stoves all our lives: from our faithful Fisher to a big CD catalytic cast iron beast, and many other stoves that we'd rather forget. We're not exactly newbies to stoves--but this Englander has us stumped--and quite frankly a bit humbled. So my wife suggested that we ask the folks who have probably forgotten more about stoves than we'll ever know...
We had the stove professionally installed, using the same outside, double-walled stainless chimney with down-draft preventing cap that vented the Fisher. We were careful to follow the steps outlined in the stove's manual. Right out of the gate, something didn't seem right with the stove. The outdoor break-in burns were incredibly difficult to accomplish, and the stove would not stay lit when we closed the door. Every time we closed the door, the fire would go out. The primary air damper seemed to have little effect on the stove during these break-in burns. We chalked it up to the unseasonably cold day, and lack of extra stove pipe on the stove during the break-in burns.
When we installed the stove we knew it wasn't in the best location in the house: a below-grade, minimally-heated basement, but the Fisher never had any issues (apples & oranges, I know), so we thought it would be fine. But it wasn't fine... nothing we do will keep a fire in this stove, no matter where we set the primary air, The best we can do is watch helplessly as the flames quickly die as soon as we close the door and the fire smolders its way to a finish.
Here's what we've done to fix this installation:
1. Installed a Draft Collar. Nothing would start this stove--not a flaming piece of newspaper, not a propane blowtorch, nothing. The Fisher started with one sheet of newspaper--I know, apples and pears. (BTW, this Draft Collar is a very good product--it keeps the flue temp between 85 and 90 degrees, and it's currently 7 degrees outside. Left on its own, in this weather, the flue temp would be around 45 or less!)
2. Added three feet of chimney. At 20-ft, the chimney is almost too tall now, but my installer says that's as high as he would go.
3. Checked our fuel moisture level--everything is under 10% on the meter. The fuel is mostly well-seasoned oak.
4. Chimney is clean, with no obstructions
5. Yes, we've done the open-the-window thing--no effect whatsoever.
6. Our installer did not recommend an outside air intake, since the stove is below grade. (He said it could be a smoke hazard, but didn't go into why.)
The strange behaviors:
1. Even when we let the flames build for 30 mins or more, with the door cracked, the flames die within 1 min. once the door is closed. Stove temps are around 300, primary air fully open. Could there be an obstruction of the primary air? I know the new 32-NC's no longer have a doghouse by the glass, and so I cannot see where the primary air comes into the stove. For now, with the door cracked, we essentially have a fireplace...
2. Even with a decent firebox of flames, opening the door more than a few inches will cause smoke to pour into the room--and yes, I'm opening it painfully slowly. It's almost as though there isn't a strong enough draft or there's some type of obstruction. Would this type of behavior come from a faulty primary air damper? The double-layer of ceramic batts above the secondary burn tubes look to be OK, but not really certain what faulty ceramic batts would look like. We've never achieved a secondary burn anyway.
3. Could this just be a draft issue? Having the primary smoke route to the flue just a few inches from the door (and only a few inches wide at that) sounds like a recipe for smoke rolling out of the stove, so I'm guessing EPA-rated stoves probably need better draft than say an old Fisher Mama Bear. But then, I'm not an EPA-rated stove designer.
For anyone who has read this far--many thanks. I'm calling the company tech line on Monday, but hoping that someone with more experience in this forum might have a solution.
Stay warm,
-Mark
Stay warm,
-Mark
