Englander 32 Modification
No creosote issues, even with the included barometric damper...heck, I'll check the chimney and have occasionally skipped the annual cleaning.
Yes, computer keeps the firebox hot/clean...in the case of the Kuuma they have an adjustment for heat output desired...that basically just raises the firebox temp that the computer is looking for.
On the other brand the thermostat calling for heat raises the firebox temp that is expected.
On my seventh with the Kuuma. I have a block chimney and tile flu. Chimney is 32" feet tall. This is the first I have cleaned it. For the small amount of ash I ended up with I can honestly say it didn't really need it.
Reactions: brenndatomu
Yes I only shut the damper when necessary. Which last night it was actually necessary to shut it all the way unfortunately.
After the season is over I’m pulling the stove and adding an actual secondary air control and the ability to completely shut down primary as well. I want complete control over a fire burning inside my house no matter what. If I have to sweep once a month so be it.
Yes, there's a big difference in draft when it gets colder out. A few days ago it was 25º in the morning and closing the damper was necessary on our stove too. This morning it was 40º and there was no need for using the pipe damper.
Have you been using a manometer as well to measure your draft in conjunction with the damper?
I am looking for a woods stove and saw this post. This one sound dangers to have. Looked at the manual and I thought it said not to have a damper in the stove pipe.
I rather have a damper than a runaway stove. If you chimney is 20+ feet, you are going to need one regardless of what the manual says .
Reactions: weee123 and NickW
This! ^ ^ ^
In January '23, I bought an Englander w06 to replace my tiny Jotul F3CB, but I found that with the new EPA 2020 cert, this thing allowed in a crazy amount of air, and the amount of heat was amazing. What really astonished me is the "blow torch" or maybe a "bellows" effect from the dogbox (some call it a dog house but Englander calls it a dogbox in their manual -"tomato - toh-mahto"). I remember years ago people posting about this newfangled stove (the 30NC) and how much wood they could pack into it (stove tetris). They also mentioned about this new thing near the front of the firebox called a dogbox and the effect it had on the way it burned wood.
I had a tough time keeping this thing under control and I even found that I was using quite a bit more wood, compared to my Jotul but then again the w06 is 3 times the size. Temperatures were often close to 700 degrees and sometimes kissing 750. Not a fun thing to happen at bedtime.
However a few weeks ago, the "roof" of the dogbox collapsed and so I ordered another one from SBI as well as two door pins and a door gasket for an eye watering price of $155 CAD". However, I noticed that after the dogbox was no longer functioning, the fire was far more under control and I'd estimate that I was shaving off at least 50 degrees and maybe even closer to 100. I'll go the rest of this winter to see how things go but at this stage, I just may not even put the dogbox back in (cover the space with a brick) as the fire is far more civilized and easier to control. If I use a fair amount less wood this year, then the cost of the dogbox would have been paid back.
I have noticed that Englander and Drolet no longer sell stoves with a dogbox inside, don't know of any others, so I think I'm good to go.
