Hi Folks, I am in the process of having my old Harmony 5 woodburner installed
Uploaded a couple of pics so you can see what's happening ....
photo details as follows :
~ Stove direct on tiled floor, as, I am told, hearth is not necessary..
~ Hole in ceiling goes straight up into loft room..
~ Woodchip panel has been removed from loft wall to access the point at which the chimney stops. The pipe will remain exposed to vent into the loft.
...Due to the nature of the chimney which is at least, 200 years old, most unfortunately, inserting a liner is not going to be possible, as the chimney itself is very narrow... so it is just a pipe up through the ceiling, then through the loft wall to acess the existing chimney ( Most regrettably chimney does not extend down into room below .
Also, installer has had to fit a new chimney pot, as the old one had been removed and the chimney sealed over thickly with cement.
Due to the extremely wet and often, wildly ferocious weather conditions here ( I live at the top of a mountain ) I asked to have a chimney cap fitted.....The installer fitted a cap which has a bird guard attached, he stated that bird guards often get gunged up with soot......and that he wouldn't recommend them personally ....
I am somewhat perplexed as I did say, ok, best remove the bird guard then ... but he has left the bird guard in tact all the same !
Prob is I do not wish to incur ongoing inconvenience and expense having to employ someone every time the guard gets blocked up with soot.....
However, at the same time, admittedly,I ~ AM, also, concerned, at the possibility of a bird making a nest in the chimney at some point, and the hapless bird and its chicks being burnt alive, This is proving a most terrible dilema for me ... I do not know what to do for the best ....
Do I keep the guard or get it removed ?![Confused :confused: :confused:](/talk/styles/default/xenforo/smileys/confused.gif)
I am between a rock and a hard place with this ...
What do I do ?????![Down :( :(](/talk/styles/default/xenforo/smileys/downer.gif)
![EFEL, AWKWARD INSTALL IN OLD COTTAGE + BIRD NEST DILEMMA ! EFEL, AWKWARD INSTALL IN OLD COTTAGE + BIRD NEST DILEMMA !](https://www.hearth.com/talk/data/attachments/161/161519-31539a49a41748dd84ed6e60d9522b16.jpg)
What do I do ?????
![EFEL, AWKWARD INSTALL IN OLD COTTAGE + BIRD NEST DILEMMA ! EFEL, AWKWARD INSTALL IN OLD COTTAGE + BIRD NEST DILEMMA !](https://www.hearth.com/talk/data/attachments/161/161515-8bff10ce08aca87a7cfa11fc95298262.jpg)
![EFEL, AWKWARD INSTALL IN OLD COTTAGE + BIRD NEST DILEMMA ! EFEL, AWKWARD INSTALL IN OLD COTTAGE + BIRD NEST DILEMMA !](https://www.hearth.com/talk/data/attachments/161/161516-9db6917eac098a10cd26ebdc114a5b47.jpg)
![EFEL, AWKWARD INSTALL IN OLD COTTAGE + BIRD NEST DILEMMA ! EFEL, AWKWARD INSTALL IN OLD COTTAGE + BIRD NEST DILEMMA !](https://www.hearth.com/talk/data/attachments/161/161517-37b4a9780f1ad20b0d26653e24710a80.jpg)
