kennyp2339
The only downside I can see to buying a cat stove to burn WFO 24/7 would be a tube stove could do it for a third of the cost but whoever needs that needs a bigger stove. The only guy I can think of who comes closest to burning this way is a member of this sight and loves his cat stove!
What I'm getting at is why would a hybrid be needed then? If they could get the best results with a cat only stove they would. Why complicate it if it isn't more effective? I'm sure it's not a huge difference, but some companies are aiming for the very best results.
The hybrid design is to burn cleaner when there is a large volume of wood outgassing at once. It adds secondary combustion for a more complete burn. This should also translate into more heat produced. The cat is for low burn rates and secondary combustion is for high burn rates.
Highbeam, when you burn at the lowest setting do you get any smoke smell at all in the house?Emissions. Cat stoves can do anything a hybrid can but at high burn rates, the hybrid design allegedly burns cleaner up top. If lower emissions is your #1 priority then you add the noncat gear. Conversely, a noncat has a hard time burning low cleanly so to try and clean up the bottom end of a noncat brands have added cats.
This all sounds great if the final product is able to burn slow enough to be competitive with full cat stoves.
I know a guy who burned his PH for several weeks with the bypass open. He claims he didn't damage the stove but when he turned the air way down, he loaded up his chimney with a lot of creosote and soot. I would rather shut the stove down then take a chance..Yes, it would be very inefficient to run it with the bypass open, but possible. The stove would essentially be running like an old smoke dragon. Some hybrids might be better in this circumstance.
Heck Woodstocks own cat only stoves look pretty darn good! I "think" I remember reading the smaller fireboxes are easier to get to burn clean. The latest data for Woodstock stoves was missing in the Jan 2015 EPA report.
