Ashful
I think there are advantages to having a larger space, or put otherwise, larger than the stove can heat 100%. In this situation, you can just keep the stove going at whatever rate you want to load it (I do 3x per day on one, and 2x per day on the other), and it's just adding BTU's to the large capacitor I call my house. The boiler kicks on and off as needed, to keep our desired setpoint, but it's really only handling a small part of the overall load. When the programmable T-stat calls for 70F a half hour before we arrive home, it's only bringing the house up from 68F instead of 62F, and the heat doesn't run all day while we're away, with the stove going. Same situation overnight, with the T-stat calling for heat in the AM.One final note. You may want to consider if you really need a house that size. The smaller the house, the easier to heat. You don't have to go super tiny, but something in the 2000sf -2500sf range is plenty of house.
![[Hearth.com] cat and non-cat questions [Hearth.com] cat and non-cat questions](https://www.hearth.com/talk/data/attachments/152/152837-d1203286f562ae0f2a8ffc3856e8bd5f.jpg?hash=KHBXqe4V7P)
![[Hearth.com] cat and non-cat questions [Hearth.com] cat and non-cat questions](https://www.hearth.com/talk/data/attachments/152/152836-d411863a274db7192fb24e064cdc6ba3.jpg?hash=lv3P8QNig-)
