Yes I'm leaning towards a hybrid if I go with a cat, which sounds like my best bet For a wide range of heating ability. I plan on plenty of window's for as much solar gain as possible too.the new hybrids might be worth a look best of both worlds
sorry not true at all you might get away with it but you will absolutely have more buildup and reduced draft. It would be a very bad idea to just run 8" before deciding on the stove
Yes, its livable space. And there is a sliding patio door right near the stove. So supper easy access!Shew. So, it's a basement, but not really a basement? Is there easy outside access to bring wood in?
How long do those cats last when consistently run like that?
In my stoves, or any other? [emoji12]How long do those cats last when consistently run like that?
If working, does one have to get up earlier to feed and trim a cat stove?
The best thing about a hybrid stove is that whether you want a high, medium, or low burn, it provides you with the best efficiency. Doing a high burn with a cat stove is not nearly as effective as a high burn in a tube stove. Both work well, but the tube stove is built for that. A hybrid just switches from cat to secondaries. During a medium burn, the stove automatically decides which technology is most effective. A low burn settles into a long lasting cat burn.
The best any run of the mill wood stove can do is run at approximately 700*f while burning particulates, i.e smoke.
Not sure I can totally agree with this statement. The best any run of the mill wood stove can do is run at approximately 700*f while burning particulates, i.e smoke. How does a tube stove do that any better than a cat stove?
My stove that cruises along at 450-550 hour after hour with no smoke would tend to disagree with you. If what you say is true, no non-cat would ever pass two of the stages of the EPA emissions testing.
My point was that there is a slight advantage using a tube stove on a high burn. The advantage may not be noticed. If all I did was high burn rates it would be sort of pointless to buy a cat stove wouldn't it? This is where I believe a hybrid gives you the best technology for however you choose to run it.
If I run my Quad at 700, it's not going to keep that up for very long and then will continue dropping off over the next 10-12 hours until a reload is necessary. What happens when you run the Princess at 700?
The only downside I can see to buying a cat stove to burn WFO 24/7 would be a tube stove could do it for a third of the cost but whoever needs that needs a bigger stove. The only guy I can think of who comes closest to burning this way is a member of this sight and loves his cat stove!
