Easy Livin’ 3000
It's amazing how much difference loading e-w can make vs n-s, isn't it?I've been experimenting with E-W loading and that has helped. I can load it in the middle or back E-W and it will slow down the burn quite a bit without turning down the air. So I'm trying about 30lbs of oak tight in the back and drop one or two smallies on the front coals to start it up. Got too eager last night with it barely active and woke up to a cold stove...
I still think the two 45s are worth a try. Do you think you will be building a chase? That would definitely keep the cold wind off your pipe. Maybe even insulate the chase with some roxul.
Here's a radical solution until you get that baby growed up a little- Apparently, there's an Englander stove on sale at Lowe's for about $700. Pull that Ashford and store it for a few years and put the Englander in for a few. After a few years, try the BK again, and if it works for you then, you can probably sell the Englander for just a couple hundred less than you paid for it. Work on getting some wood to primo dry condition during the three year hiatus.
Yes, tons of hassle moving those big heavy stoves around, but a small investment, and it may get you where you are trying to go.
