I do the same on the 88cc. Full skip on the 36". 28" and 22" full comp.I run skip chain when I mount my 36" bar on the 85cc saw, but full comp at 28" and below.
Skip is also quicker to sharpen!Cool! In addition the sharp chain and never taking the depth gauges below factory height if you don't have the extra HP, I'd say skip chain is also key for any "over-barred" saw. Skip chain takes substantially less horsepower per inch, it has half (or 2/3, depending on config) the cutters, but also cuts slower and can be too grabby if the thing you're cutting isn't big enough to keep at least 2 or 3 of those widely-spaced cutters buried in the kerf.
I have a little dolmar 421 that I muffler modded and tuned. It's a good little runner for cutting smaller stuff. Always starts on the 2nd pull and is ready to work.I occasionally run a 28” skip on my echo 590 for felling and bucking big trees. Otherwise it hangs out with the stock 20” on it which it rips with.
I mainly use an echo 3510 for limbing and small stuff with a 16” and now that I ripped off the limiter caps off the carb it runs really nicely. I also took the limiter caps off the 590 to tune it to run properly with the bigger bar.
I also have an xl12 homelite that I play around with for bucking some logs for funsys.
“Stand up and buck” BBR puts 32” on just about everything but he’s special
My first several firewood saws were all dad's, but when I moved out on my own I got a 1970's Homelite Super EZ-Auto, which I think was all of 40cc. It ran a lower RPM and I believe had a smaller sprocket than you'd see saws running today. It was slow, but it had grunt, and would go through anything without bogging. I think it had a 16" bar, IIRC.Before I got my 3510 I was using my grandfathers skilsaw 1616 from the 70s. I cut up a lot of firewood with that saw and felled quite a few trees with it.
I have my Grandpas Super EZ Auto on my shelf. My Dad ran across it years ago and gave it to me to put on my shelf. It was filthy. I cleaned it up, put new fuel lines and all on it, rebuilt the carb. Ran it cutting up part of an oak one day. I do believe it's 40cc as you said and ran full 3/8 chain. As you said, low rpm but it had grunt. After using it that day I cleaned it back up. Emptied the fuel and put on the shelf. Pretty neat to have my Grandpas old saw and one I would never sell. My Dad unfortunately passed away July 22 2022, 1 day after he turned 68 years old. I am fortunate to have his McCulloch PM610 he bought new in the late 80s when I was a few years old on the shelf as well. He sure cut a lot of firewood with that saw and I watched him run it quite a lot. Man I miss my Dad, my hero and a great person, lost him to soon but thankful I got the time with him I did, some aren't as fortunate.My first several firewood saws were all dad's, but when I moved out on my own I got a 1970's Homelite Super EZ-Auto, which I think was all of 40cc. It ran a lower RPM and I believe had a smaller sprocket than you'd see saws running today. It was slow, but it had grunt, and would go through anything without bogging. I think it had a 16" bar, IIRC.
Many saws have come and gone since that one, but sometimes I wish I had kept it, just for nostalgia. It had a certain vintage appeal, and sounded very cool, next to these high and whiny modern saws.
That’s why I love my xl12. Sounds great and has super low end torque, able to pull a 20” bar at only 54cc with no problems buried in oak. I’m probably going to cannibalize it to get a super xl I have running though.My first several firewood saws were all dad's, but when I moved out on my own I got a 1970's Homelite Super EZ-Auto, which I think was all of 40cc. It ran a lower RPM and I believe had a smaller sprocket than you'd see saws running today. It was slow, but it had grunt, and would go through anything without bogging. I think it had a 16" bar, IIRC.
I got a Super XL Homelite to. I believe it was a newer one. It's got the Old Blue label on it. It's got some grunt to it. I think it's 58cc? I bought from a guy on Craigslist years ago. Cylinder is scored but it still has good compression and starts.That’s why I love my xl12. Sounds great and has super low end torque, able to pull a 20” bar at only 54cc with no problems buried in oak. I’m probably going to cannibalize it to get a super xl I have running though.
Wow, great story, and thanks for the memories. That is the exact saw I had. Mine was real clean, and totally complete, even with the little tip guard for the OEM bar (which of course I had removed, but kept)! I guess they must've sold quite a few of those saws, just hearing from our little group here.I have my Grandpas Super EZ Auto on my shelf. My Dad ran across it years ago and gave it to me to put on my shelf. It was filthy. I cleaned it up, put new fuel lines and all on it, rebuilt the carb. Ran it cutting up part of an oak one day. I do believe it's 40cc as you said and ran full 3/8 chain. As you said, low rpm but it had grunt. After using it that day I cleaned it back up. Emptied the fuel and put on the shelf. Pretty neat to have my Grandpas old saw and one I would never sell. My Dad unfortunately passed away July 22 2022, 1 day after he turned 68 years old. I am fortunate to have his McCulloch PM610 he bought new in the late 80s when I was a few years old on the shelf as well. He sure cut a lot of firewood with that saw and I watched him run it quite a lot. Man I miss my Dad, my hero and a great person, lost him to soon but thankful I got the time with him I did, some aren't as fortunate.
Here is a pic of that super ez of Granddads.
Oh yeah I remember seeing the tip guard on some in pictures I had seen. Its a neat little saw, its pretty light weight and I remember the angle of the manual oiler is just perfect to hit it with your thumb if needed.Wow, great story, and thanks for the memories. That is the exact saw I had. Mine was real clean, and totally complete, even with the little tip guard for the OEM bar (which of course I had removed, but kept)! I guess they must've sold quite a few of those saws, just hearing from our little group here.
Nice! I'm on nearly the same 3-saw plan, I even have a T435, my 63cc and 85cc models are older Stihl pro saws. After trying several combinations, I'm convinced this is the best saw plan in terms of sizes, no matter the brand.So my 3 work saw plan is going to be the T435, 562XP, and 390XP.
Thank you! Yeah I believe this cc spread is good. The 562 is going to open my range up more before I reach for the heavier 390 than the 550 would have.Nice! I'm on nearly the same 3-saw plan, I even have a T435, my 63cc and 85cc models are older Stihl pro saws. After trying several combinations, I'm convinced this is the best saw plan in terms of sizes, no matter the brand.
I believe so as well. I went back and forth between the two over and over and over. I ran the 562 some more yesterday. I had some small stuff to cut to firewood length and had some oak that I had split as much as I could but had nasty knots in them so I noodled them with up with the 562.I think you made the right choice. If you're used to 90cc, you would have found the 50cc too wimpy for satisfaction. Heck, I feel that way most of the time about 63cc, after using 85cc, and they're not as far apart.
Not sure if this is directed at me, since I had mentioned this a few posts back, but here's my thinking on it:Are you finding that you like having those larger dogs? I do not fell much. Just trees to cut for firewood but I feel that some extra bite while bucking our hardwoods may come in handy. Are they worth it?
I personally like the bigger dogs. Back when I bought my 390XP new it came with dual dogs but they were small and I found it aggravating to get a good bite sometimes when bucking. So on the 562 it only came with 1 single sided small dog so I ordered the bigger dogs from Husqvarna at the time I purchased the saw and put them on before I ever even put fuel in it. I cut hardwood so as of now I have kept my depth gauges on my 562s chain at .025" and it lets me dig them in and still keep the RPMs up. Not everyone may like big dogs. And as Ashful said on a smaller saw such as a 35cc I would not have them on there and it would take so little to stall it.Are you finding that you like having those larger dogs? I do not fell much. Just trees to cut for firewood but I feel that some extra bite while bucking our hardwoods may come in handy. Are they worth it?
While I am at it, do you also find that you like that trailer? I have a homemade wagon I haul wood with but its limited on the speed I can go with it. I would like something like that behind the 4 wheeler.
