I think a cat running between 650 and 900 is just fine. North of 1300 may be considered too hot. The Condar web page says above 1300 for the steel cat is too hot and may cause it to not function. But other VC stoves have a ceramic cat which maybe different.
- At 650 to 900 I definitely see and smell smoke out the chimney. I think it is fine to run the stove there but it is definitely not running well or as intended. I would keep an eye out for creosote build up.At 650 to 900 are you seeing smoke out the pipe? If yea you are too low
- For the Defiant model 1975 the only cat available as far as I know is the ceramic version. Would love to try a steel one just to see what the effect is, with this stove design it would probably melt the steel cat on the first full load.You have the option purchasing either if its made for your stove. My stove came with a ceramic, but I run a steel one as of last year. steel lights off easier and doesn't get as hot..
Random question. How often is everyone cleaning out ashes? Everything that you read says to keep a couple inches of ashes, but that just makes a giant mess when I go to open the ash cleanout. I've been doing to before i start every fire lately.
The Intrepid ashpan is small. I de-ash every morning so yeah, the pan is at least 3/4 full or more.I empty my pan once it is full 1 or 2 times a week, yes it makes a mess if I delay too long. I try to leave ash on the grates and then knock it into the pan when it gets too thick. 3-4".
Surprised the intrepid ash pan fills up in a day... Seems too quick, but I have no experience with an intrepid.
Leaving a bed of ash seems to calm the stove down a bit, but it is not a big difference.
Averages 12" L x 6" W x 2" D. The length isn't a perfect rectangle but average in the middle is 12". The pan won't fill up with ash on its own much, you have de-ash the grate in the morning to leave the coals behind for the reload. But all the modern VC stoves have the same set up I believe. I had an Encore 2040 about 4 years ago and I know that ash pan was a lot bigger, but yeah a bigger stove.didnt know the ash pan was that small.. what is the rough actual size
Yeah, I remember that. Co-worker on the eastern shore bought it.yes. that is a small pan. I remember your 2040, I sent you a pm about purchasing it from you, but you already had it sold
Surprised you can not get a definitive answer to your question, unless I am missing something. The secondary coil is a bimetal that reduces secondary air when the cat temps rise. Sounds like yours was not working very well and now it is? 1300 peak on the cat after a hot reload sounds like a dream to me....FWIW I wanted to post a followup on my cat situation. Someone mentioned new cats being very active. My new cat has been very active but it seems to be settling down now. After a hot reload to a full firebox last night the cat rose to 1300's then settled and cruised all night. 11 hours later still plenty of coals and cat was 5-600. Hot reloaded a few splits and the cat rose nicely. maybe this cat is trainable after all. Really didn't like that bright glow at 1600+.
Still can't get a definitive answer on what the secondary coil controlled shutter actually does on the back of the stove.
That's the whole thing, I don't have secondary air control as it's controlled by a thermostatic coil that no one understands what it actually does. and not sure exactly what it does. Cat still is pretty active and has shot up on me after I posted this, still can get out of control. If I close primary air a little too much the firebox will flash over and push a puff of smoke past the griddle. Local dealer said that's pretty common, and this stove has always done it. I was on the phone with HHT (VC) today again and had a woman that really tried to find the info on what the secondary air actually does or how it's supposed to work and she could not find any info on it. She said no one that works there would know anything about it. The only thing she could come up with was the copy of the stove's original manual which I already had. It mentions the secondary air but doesn't say how it actually works. It only says that it is controlled by temperature inside the combustion chamber and it meters the secondary air. It says it is supposed to compensate for wood that isn't seasoned enough. I don't see how it does anything as it closes as soon as it gets warm.Surprised you can not get a definitive answer to your question, unless I am missing something. The secondary coil is a bimetal that reduces secondary air when the cat temps rise. Sounds like yours was not working very well and now it is? 1300 peak on the cat after a hot reload sounds like a dream to me....
Wish I had secondary air control on my stove. Sadly they "improved" the design and made it "self regulating"..... Mine "self regulates" anywhere between 500 and 1600 F.... depends on the phase of the moon and the mood my wife is in. (not predictable)![]()
