Hello All, Glad to see the forum is alive and well....
I have a 10 year old Defiant (2n1) model 1975 and have been fighting with it for all 10 years (See posts from years past). Issue is cat temps up over 1500- 1700 F, but not consistently. Some times it will be fine for a week, (cat at 1200-1300) then it gets cranky and decides I am getting too much sleep and it wants some "quality" with me, usually around midnight.... it is a love hate relationship. I burn 24/7 in the winter, ~4 cord a year, all under a metal roof shed, aged at least 2 years. MC <15- 18% (usually....
Last year for the first time I plugged the secondary air to varying degrees, it definitely made the stove more controllable, but I too had massive creosote buildup.... Had to clean it out late winter, nearly blocked an 8" chimney liner. Never had a creosote problem in years past, clearly there was not enough secondary air.
I have plugged every hole there is to plug, screws in the 8 holes in the fireback is the most effective in calming things down but not 100% effective. This year I have the secondary open and trying to keep cat below 1300 - 1350.... it is mostly futile..... it is not at all clear to me what is "too hot". Some say 1300, some say 1500 and everything in between.
I also suspect air likes to leak around the door seals, particularly the glass panes. Seems like when I replace or tighten the glass screws things get better, but not completely.
I am on my 3rd refractory set, (yes it requires a complete rebuild) all were cracked and new parts under warranty (thanks VC). Lucky me I have a lifetime refractory warranty. I go through cats every 2 years, almost like clockwork. They crack and fall apart. I don't even care anymore about replacing cats.....
My feelings are that this "new" 2n1 design is just not very robust. Having no air control on the secondary air seems like a really bad design choice to me. I have friends who have older Encores with bimetal temp control secondary air and their cats cruise along at 1200 for hours, steady..... Might see 1400 spikes once in a blue moon.
Another design flaw (IMO) is that the secondary smoke inlet is at the bottom of the stove. It is like a vacuum just sucking flame right off the hot coals. I have seen evidence of flame impingement on the refractory all the way to the cat (heavy spalling and flaking). The older stoves took smoke off the firebox nearer to the top, so that flame has a chance to burn out. Also different is the secondary air routing, in the new stoves the secondary air can support primary combustion by leaking into the firebox, in the older design there is no place for secondary air to go except to the cat. Gives the primary air lever more positive control of the burn.
My stove gets very cranky when I do a hot reload (Cat >500F with a glowing bed of coals), even if I let it sit with the damper open for 20 - 30 min to burn off the soft wood, in an hour or two it will be screaming at me (cat 1400+). I gets really mad if I have some moist wood in there or throttle air down too quickly resulting in a smoldering fire with low griddle temps (300 or less)..... So I try not to do that.
Below is an plot of data from yesterday (I bought a 4 channel TC data logger)..... You can see I did a hot reload at Cat=600F, red arrows are where I opened the damper to try and save the refractory.... twice. Took a couple hours but finally settled down. I am tired today....
Bottom line is I do not have an answer on how to control this sucker...... I can make it better, but not completely. I have reached out to VC several times and got no response.... I guess I will keep putting in warranty claims till they decide to address the issue, or not...
That being said, I love the stove when it runs good, it has so many great features, throws a lot of heat and burns all night. As the burn season progresses I keep raising my Cat temp alarm, I start at 1300, now it is at 1450, in a week or two it will be at 1550..... I need to get some sleep.
Happy to hear other opinions or suggestions and I hope this at least provides come comfort to those struggling with the same issues...... you are not alone!
