I 'll pull the temp probe out carefully and gently brush it occasionally, sometimes build up accumulates on it.
I may need to do that as well
How do you guys start your stoves? I’m seeing pictures of stoves that are jam packed and no fire going on. Or are these pictures just showing how you will eventually fill the stove once you get a fire going?
On my Regency, I use 6 pine cones (3 on each side) and put 3 pieces of kindling on top of them. Then newspaper on fire and everything starts going. Once the 3 pieces of kindling are on fire, I put a few more kindling pieces (or small sized splits) and once that catches I start putting the bigger pieces in.
Is it different with a BK?
I start a few fires a year. I shut down for cleaning at the end of fall (because I've been burning the stove very low for months) then one day in early spring. One more cleaning sometime in the summer after the burning season is done.
Come to think of it, that middle cleaning is kind of a waste because there's no crud to sweep after a winter of hot burning. I should do middle of fall, start of winter, middle of spring, summer... that way I'm always sweeping after a period of low burning.
It's overkill maybe, but it's free and doesn't take long.
I've also found that if I do oak for the last load and add some ash from my ash bucket, the flue cools off nicely and I can still reload on hot coals after I scoop some ash and give the coal some air.
So maybe I'm technically down to starting 1 fire a year... though maybe I'm on a short list of people whose sweeping routine includes "examine brush for melted bristles"...![]()
Does everyone with BK sweep multiple times a year. My installer told me once a year is fine. I have about 25 feet stack and don’t intend to go up to clean it. I plan to have it sweeped when the season is done.
I remember BKVP said you could clean it from bottom to to top. What kind of tools you need to do bottom to top cleaning?
I never did before, but a clogged combust or forced me to shut down and pull the cat last week, so I went ahead and swept while it was out. I use a Soot Eater, bottom up, thru the bypass door. All crap falls in the stove, I just reburn it. I did it with live coals still in the stove, about 24 hours into a burn, probably not the recommended method.
So you normally dont do mid season cleaning then. I will have it sweeped when the burning season is done. I will also ask the sweeped if he can also clean my chimney cap which turn into blackish color.
I found this on amazon:
Gardus RCH205-B SootEater Rotary Chimney Cleaning System https://www.amazon.com/dp/B0010H5JXA/?tag=hearthamazon-20
Any videos on how to start a stove when it is jam packed? I have no idea how you could do this.
Future owner of a Princess.
)Any videos on how to start a stove when it is jam packed? I have no idea how you could do this.
search "top down" fires
Once per year is plenty for me. I burn for 9 months each season, mostly evergreens, and mostly on low.
Not a fan!
On a cold start I load it full and either place a chunk of super cedar in the center or one chunk on the right and one on the left. I split my super cedars into 1/8ths.
I usually sweep twice(for piece of mind) as the seasons change. Once when the fall shoulder season turns cold and once when the cold turns to the spring shoulder season.
Unlike your noncat, the princess has a 6” belly below the door opening. The photos of a full box can’t show that bottom 6” which is where most of us stack a little crib of kindling in the middle before filling up with full sized splits. Then ignite the kindling with a supercedar or a torch (my choice) and the rest of the load will catch.
You’ll need dry wood for several reasons including the ability to rapidly start a fire without coals.
I’m also not a fan of top down fires. Not in any stove. Lots of people seem to like them though.
I do one center right on top with son small/skinny pieces and two pieces, one on each side about halfway in the load. I like it cause the cat gets to Temp real quick.Not a fan!
