7 good size splits fill my Princess
I’m still at the 10 split load point but I’ve been splitting bigger and bigger so in the next few years I’ll get to those larger splits and maybe 7 split loads.
I see absolutely no good reason to ever do a top-down fire in a BK.search "top down" fires
My cold-start procedure:Any videos on how to start a stove when it is jam packed? I have no idea how you could do this.
Future owner of a Princess.
I'm also using 10 splits, but I probably have to spend a bit more time and thought on my Tetris, given my firebox is 3.5% smaller than yours.I’m still at the 10 split load point but I’ve been splitting bigger and bigger so in the next few years I’ll get to those larger splits and maybe 7 split loads.
What are the optional side shields for and what do they do?
What about the optional convection deck? What is the purpose?
Outside or inside shields? Convection deck? Well, thats what it is it convect the heat and route the air from the fans to the front.What are the optional side shields for and what do they do?
The optional convection deck looks good and also forces air from the blowers to spend more time in contact with the hot stove top to strip more heat
Fans, it is another way to call it.What does he mean by blowers?
If you live in the Alps, maybe it never warms up all winter? It went to 32 degrees here, this afternoon. By the time I took a quad load to my BIL and played with his stove for a while, my stove was out by the time I got back home. The house was still at 68*. No problem to fire back up (see later in this post.) Lighting a stove is no hassle at all if you're an expert like I am.And most of us BK owners start from a cold stove around October, from there on it’s always reloading on hot coals, usually every 12 hours or so... that’s why you see stoves filled to the top with big splits. With warmer weather, same thing but on a 24 hrs schedule.
And this post just sails past everyone, nobody even asks "why"...Maybe only clogged with ash, and run-of-the-mill?a clogged combust or forced me to shut down and pull the cat last week
Even though you can't hear me, I'd like to thank you for the heads-up. Gonna have to get me one of those toys..Consumer grade wifi endoscopes are cheap on amazon and can be used to inspect the entire flue from the bottom up.
You BK folk act like it's a big deal to start a fire. Sure, I have to have some kindling, which requires some effort to work up, and I need a stock of quick-catching splits..Red Maple is my favorite. Once I have that stuff, starting is a breeze. I might do a top-down, or a bottom start with fast-catching wood on the front. I have a couple of large clinkers I've saved in the stove, I drop 1/7 of a SuperCedar between them and put a couple of kindling Pine fingers on top in the front of the box, and waited about 10 minutes. Then I pack the rest of the stove (Red Oak usually) and put a couple Red Maple splits on top of the kindling in front. Shoots heat to the top, in the front, pretty quickly. When the stove is up to temp, I close the bypass. It's really not any harder than starting off coals (which I usually do anyway.)Here's the Princess Technique: Throw the wood in, the wood ignites because that stove has a 24+ hour burn time and you only need to light it when you let it go out on purpose. You could use your blowtorch if you want to get all fancy.
The one time a year that I actually start that stove from cold is in the fall, and I traditionally start it with a few stoveloads of sticks and twigs policed up out of the yard to warm her up.
Not a fan!
You guys just aren't nerdy enough. If you want the absolute cleanest start, top-down is where it's at.I’m also not a fan of top down fires.
This is why top-down is cleaner; The wood that's catching (smoldering and smoking) is feeding the smoke up into the flames above, which re-burns the smoke resulting in no smoke out the stack, even on start-up.Flames go up not down.
One reason I value your input is that you are running two different stoves. Not many of this BK hoard can say the same. Sure, there are a couple guys who previously ran a cheep-arse tube stove, or a crappy down-draft stove, but...I calculated last week when I was at the cottage Wed through Sun:
5 loads for BK = 35 splits (1 load in a 24h)
At home for the same time period I get
15 loads for VC = 41 splits (3 loads in 24h with one smallish day time load)
Pretty much same heat output
Fans. I don't like extraneous noise, so I'm not a fan of fans and I think blowers blow.What does he mean by blowers?
By blowers you mean fans? Are you guys using fans on the Princess?
I just looked to see how wimpy your winter was right now, and to my surprise, not all that wimpy. You might even have some snow to deal with.I very seldom run the fans
Pics of the blower please! I’m obsessed with BK.There is an optional fan kit (aka blower) that bolts on the rear of the princess and other bk models. The fan kit reduces rear clearances and provides you the option of boosting output. I very seldom run the fans, almost exclusively when I’ve allowed the house to cool and need a rapid warm up.
You for example.Many are...
It doesn’t get super cold (we seldom hit -20C in January and February) but the annoying thing is the day maximum temp, that stays between -2 and +2 C from mid November through March, hence the 24 hrs burn.If you live in the Alps, maybe it never warms up all winter? It went to 32 degrees here, this afternoon. By the time I took a quad load to my BIL and played with his stove for a while, my stove was out by the time I got back home. The house was still at 68*. No problem to fire back up (see later in this post.)
Hey, somebody's gotta fight the good fight.You for example.
