kennyp2339
your running your stove to hot, that cat got baked... take a pic of the underside of that cat please.By the way, yes, I have 2 year seasoned wood, tight door gasket, and know and use the bypass protocol from the
If you have excessive draft the flow out through the Combustor will make it hot (to much fuel and air mixture) and the Combustor overheatsI am a bit confused.....
How can you run this stove too hot?
I beg to differYou can't if your install is to spec, and your gaskets are good.
I beg to differ
What does that mean? Can I get the stove to burn pretty like a regency or will it look like it’s not on most of the time? There will be times (very few, during parties etc) where I want the stove to look like it’s on. Can I open flue there and feed it small pieces of wood to keep it burning and look like it’s actually burning?No it will burn like an smoke dragon.
Standby... im cooking dinner when I get done I’ll argue with you.. but you might have me by a technicalityI beg you to elaborate. Max draft spec is in the manual.
These stoves should only “look like it’s not on” when you turn it way down low, trying to minimize heat output and maximize burn time. Under normal “medium burn” or higher conditions, it should have nice flame show.What does that mean? Can I get the stove to burn pretty like a regency or will it look like it’s not on most of the time? There will be times (very few, during parties etc) where I want the stove to look like it’s on. Can I open flue there and feed it small pieces of wood to keep it burning and look like it’s actually burning?
Yes arguing with him is rather pointless. Even if you offer substantiating documentation it is ignored.Best laugh I’ve had this week. You do realize who you’re arguing with, right?
What’s confusing to a lot of people, and I think BK could do a better job here, is that that low “black box” setting is right in the middle of the “Normal” range labeled on our dials, for most people. My dial spins thru 11 hours of the clock, but the useable range is only 3 hours. If I lower it any more than 2 hours from max position, I have a dark black box. This is normal, but I think it confuses new users.
One thing I don't get is how does bk get away with making a stove that when installed normally you can easily turndown to a point the clean burn system stops working while noncats are not allowed to do that?If you start another debate about dial stickers, I am disowning you.![]()
I see.
How does one determine if they have excessive draft?
Ok, so HB is 100% correct with this statement; but many and I mean many people don't have draft within spec of what BK calls for (.05" while running at max setting, cat engaged) I myself never really gave 2 cents of my time to draft until this season when I went through my second cat on the stove (within 5 years) Having a higher draft than what is called for by spec allows more air to travel though the system, yes the t-stat can reduce flow but sometimes finding that sweet spot is nearly impossible, it will click over then the flames die out and loss of heat occurs during colder times when higher stove top temps are needed, or the draft is strong enough (my case) that the t-stat wont kick over unless ran extremely low (stall area) or the heat gets sucked out faster and up the flue creating less transfer for stove top temps to rise, allowing more air and fuel to hit the cat and make it self destruct with heating temps over 1500 deg f.You can't if your install is to spec, and your gaskets are good.
Yes, I do know, the west coast hungry version of me.Best laugh I’ve had this week. You do realize who you’re arguing with, right?
In an earlier post I asked a member to post pics of there underside of the cat - case, this metal will turn brown / red when overheated, just like steel in after a building fire.
Use this poor analogy - a 1" hose being used as a syphon, the tip of the hose has a predetermined size to let a certain volume of water in it (that the t-stat) the end of the hose is the chimney, under normal gravity syphon the hose at max can empty 50 gallons of liquid in an hour, put a pump on the end of the hose (chimney with higher draft) and turn it on, that same hose now can flow 150 galloons of water an hour.
So again HB is correct in his statement of within spec, but many don't even know what the spec is, what normal is as a baseline, and what there chimney draft is in normal operations, I had to fall on my face a couple times to wake up and check with a manometer.
I dont beleive for a second you write code sorry. But if i am wrong and you do it is really scary.Only pointless when you’re wrong! I’m an engineer, I write code, I can smell a poorly written code but in this case I think that section of code was purposely written vaguely so that nobody is right or everybody is wrong.
