Ashful
right next to it too but I still have not figured out any use for the bun warmer drawer as of yet. Any suggestions?
Psst... that’s an ash pan.
You must have one of the early Ashfords 30.1’s. That was fixed long ago, and a retrofit pan is available. No excuses!
Hey, I saw it pages ago! "I get no respect, I tell ya."I find it very interesting you figured it out.
2017-18 Blaze King Performance Thread PART 3 (Everything BK)Family aside, have you actually tried using ashpan?^^ Skipped the ash pan. We shovel out as needed, with the ash vacuum hose draped over the open stove door for dust mitigation.
Warm cinders go in a 55 gallon galvanized trash can on the gravel driveway. The trash can is weighted down, both in the bottom and on the lid, with masonry block. When the second can is filled, the first can is dumped and wetted down.
Honestly, shoveling out into an ash can seems easier than dealing with an ash pan. It's certainly a quick job. But I could be wrong. Neither we nor family members ever had a stove with an ash pan.
The ash vacuum helps a lot.
You won't have a chance to lay eyes (and ears) on one, before buying?Two things that are on my mind before I drop 4K on the Chinook.....are the fans and the ash removal system.
I hope you guys are right about both....the noise level being ok and the ash removal not a problem.
Well, it's crazy but the ashpan is one of those ultra personal things. Kind of like burning E-W vs N-S or to clean the glass every day or not.
Well i will give it a try. good to know.It's the same, but it lets you rake all the coals up front before loading. If you tend to reload in the middle of a load, e/w gives you less odd sized unburned chunks to deal with (because the stove still burns front to back). The burn time is better for me, but that's because I can put more wood in because I'm accumulating less coal, not because it really burns differently.
In mild weather, without a bunch of coals in the stove, or when burning softwood- not sure I see any advantage to e/w.
Was that for the insert alone or for the insert + installation?Hi Everyone, I am in Western PA. Was quoted $3900 + Tax for a BKPU Insert with a large surround and a black door. I thought this seemed high so I am going to shop around. From reading other threads it seems prices increase from west coast -> east coast. The Ashford was well north of 4k. I am considering driving to WV or other locations if the price will drop significantly.
This was without installation. The vendor did not provide installation services. So I would also have to purchase the liner, installation of liner and installation of insert from a "suggested contractor". Or do the install myself.Was that for the insert alone or for the insert + installation?
No. Pizza requires high temp to bake properly.Guys can I cook a pizza in the bun warmer?
Sounds like it wouldn't hurt to call around if you can pick it up. Here is some recent pricing in VA.This was without installation. The vendor did not provide installation services. So I would also have to purchase the liner, installation of liner and installation of insert from a "suggested contractor". Or do the install myself.
