ratsrepus
. looks like we can 31 hrs burn instead of 28 if we remove the bottom layer of bricks. My princess is boring enough.So since I never use the plug I can pull the top layer out and gain some volume?
I am thinking "mini-king".... looks like we can 31 hrs burn instead of 28 if we remove the bottom layer of bricks. My princess is boring enough.
I need a bush pilot superstar! Or is that Ratsrepus?. looks like we can 31 hrs burn instead of 28 if we remove the bottom layer of bricks. My princess is boring enough.
Possible but I doubt it with the Ultra being a pedestal stove...but even if it did I would adapt.Wouldn't that change the hearth R-value requirement, by some unknown / un-tested value?
Precisely. It was only tested with 2 layers..Wouldn't that change the hearth R-value requirement, by some unknown / un-tested value?
I just "thought" the extra layer was there to accommodate the plug...who wouldn't like extra volume?Precisely. It was only tested with 2 layers..
Yes, I figured it out. Marketing guys play with letters and wording all the time...do you understand your statement, I find it very interesting you figured it out.
RedruM.do you understand your statement, I find it very interesting you figured it out.
Jags is the master fabricator, here. I'm just a hack!Ashful? We need a favor!
Perhaps an online Blaze King Bible complete with index would be advantageous. Updatable at will. A lot if raw information and operating nuances have been brought forth in these threads.
Index
Ch1. Congratulations you have just purchased the worlds finest wood furnace.
Ch2. How to burn. Don't throw that manual away just yet.
Ch3. Dealing with boredom. When psychotherapy is indicated.
Ch5. Gaskets, cats and all the other easy stuff.
Ch6. Secrets of the magic thermostatic controller.
And far longer if we cut off the top and weld a 4 foot extension into the body.
4 is well known to be an unlucky number because 四 sounds similar to 死 (sǐ), which means "death" in Chinese.I like it.
Practically, we are somewhere between Chapters 3 and 5 in real life...
... which leads me to ask,
What happened to Chapter 4?
WHAT'S IN CHAPTER 4???
We don't talk about that in public, lest the Woodstock guys find out.What happened to Chapter 4?
Chapter 4.
"The Aliens Return for Their Lost Technology"
When it misses the tray below and lands on the floor.Ditto. I don't know how you folks who like to shovel ashes into a bucket could possibly think that's better than using the plug, but to each their own...
I did a thing.
I reloaded mine after work, had the cat engaged with the tsat on high, looked at my chores list, looked at indoor temp, outdoor temp and the clock.
I left the tstat on high with the deck fan on low. When my wife got home 105 minutes later, i was still doing chores, the indoor temp was perfect - and i didnt hurt my stove.
AND you were ready to turn up the fan and blow clothes all over the place!
