It’s common for them to lose calibration, sometimes they are off from the factory. I’m pretty sure this is covered in the owners manual...Thanks Jetsam. I don't feel so bad now!
Mine too!My thermometer has always been WAY off then! My cold mark is roughly where gregbisia's is.
And there IS a green line; I drew it myself!
I'll pull the themometer and let it cool off and adjust it tonight.
Mine too...My thermometer has always been WAY off then! My cold mark is roughly where gregbisia's is.
Looks like you're in a PICKLE
Well, who knows what to expect from a thermometer that is labelled "ON" and "OFF"? Kind of like a photospectrometer that can read "MAYBE" or "PICKLE".
This is my cat probe cooling down, at about 170° on the face of it according to an IR thermometer.
In my experience with steel cats, they heat up quicker but fall out of active sooner. They lack the thermal mass of a ceramic. They also clog up easier than ceramic. Cutting the ash is a pretty funny statement!Condar says the Steel Cat becomes active at 400F This might be a little in the "inactive" zone. I roll over the bypass when the flue hits 350-400, and stopped looking at mine as this can shave 10 or more minutes off at start-up.
Advantages of STEELCAT™ Catalysts
- A more durable honeycomb that will not crack
or crumble, even at the highest operating temperatures.- Less build-up of wood ash within the honeycomb cells. Sharp steel edges actually "cut" ash as it goes up the flue which creates better air flow and requires less maintenance.
- Lower "light-off" temperature. You can engage your draft bypass at 400°F (204°C) vs. 500°F (260°C) with a ceramic honeycomb.
- Steel heats up faster than ceramic so it recovers more usable heat from wood smoke.
To properly calibrate it, boil up some DOT 5 brake fluid, and adjust needle to line between inactive and active.
Fresh DOT 5 boils at 500F.
(April fools)
The advantage comes at the end of the burn. The cat is still hot enough to fire off immediately after a reload. The difference isn’t much I know, but I prefer the ceramic. It has been more predictable.I am running a steel cat in my princess insert now. I like it well enough that I might stick with steel. No clogging issues yet.
I feel like a 100° lower active temperature is a much bigger advantage for me than some thermal mass; I don't care if it goes inactive 30 minutes sooner at the end of a 20 hour burn when there's nothing for the cat to burn anyway. I DO care that I can run the stove dialled down all the way to the stop and be confident that the cat won't fall out until the fuel is gone.
I'm trying to understand this objection. While this is a real issue for fully sealed operations with a furnace or hot water heater, aren't most OAK for stoves unsealed. Unless the it's a sealed outside air intake, if the vent gets blocked, you're right back where you started, pulling air from the room, no?If it gets blocked with snow or other debris, it could cause performance issues.
I like the line of footprints going directly under the grill. V. short person with v. large feet!Even with 500 degree flue temps, even in mild Washington, we still get creosicles. This is more like yellow snow really.
The pellet bbq is cranked up for some tri-tip too.
I replaced my first one after 2.25 years and one cleaning (~12000-15000 hours maybe). It still glows red on high, but doesn't handle low burns like it used to. I went from ceramic to steel, which has been educational.
Manufacturers rate cats at around 10k hours; BKVP says his current cat has gone 10 years?? There's not much clarity on actual service life; I guess a lot depends on how much performance degradation you are prepared to accept.
Pull your CAT probe outa it's place and clean the buildup off of it, see if that makes a difference, let us know..
I replaced my combuster after about 10,000 hrs, but my digital readout was about the same,,,, CAT probe had a bunch of buildup on it, cleaned it off, and it was much better..
... or chimney height. I’m running two identical stoves with identical steel cats, and only the one on the tall chimney clogs.I like steel significantly better than ceramic so far (2/3 of a season on), but they both get the job done. I haven't had the plugging issues others have reported; I don't know if that's down to wood or stove design or burning habits.
