bens_igloo
Hi all,
I am questioning the effectiveness of the CAT in my BK princess installed this season and burning regularly since Sept this year. I am looking for some views to confirm if this is the case or if the behavior is normal.
After closing the bypass it takes a little while for the gray smoke to dissapear and I hear this is normal. However even throughout the burn there is white smoke that dissipates pretty quickly but not instantly. My chimney goes out through the roof, and looking out from the window I can sometimes see puffs of smoke dissapear. Maybe that helps to explain what I see. I looked down the chimney this weekend and there isn't a huge amount of creosote, but it is quite oily (I think it is oil, maybe something else though?)
When I compare it to my non-cat stove (PE Summit) there is definitely more smoke and more smell.
Visual inspection of the cat shows no cracks, peeling, or warping.
A bit of information about my setup:
- I am burning fully seasoned (2-3 year ash)
- I checked for air-leaks around the door and there are none
- Stove has never been over-fired.
- I always wait until the thermometer is in the active zone to close the by-pass. I've also always opened the by-pass before opening the door.
- I burn the stove on high for maybe 30 minutes a day, but never let it go above the the top of the active zone on the BK thermometer.
  You can sell the skidloader and one of your stoves to finance it, and then save big on hovercrafts and fuel oil and back surgery.
